Could you tell me if this is possible to do action based on specific actions? I mean, do an action based on specific conditions and not all conditions without need t create a new automation scenario?
Example with my current scenario:
- id: '1572631476783'
alias: Fermeture volets automatique
description: Fermer les volets durant la nuit
- below: '100'
entity_id: sensor.illumination_xxxxxxxxxx
for: '1200'
platform: numeric_state
condition:
- after: '16:00:00'
condition: time
- condition: and
conditions:
- condition: or
conditions:
- condition: state
entity_id: cover.volets_rdc
state: open
- condition: state
entity_id: cover.volets_etage
state: open
- data:
entity_id:
- cover.volets_rdc
- cover.volets_etage
service: cover.close_cover
My goal is to close volets_rdc only if this group is open and close volets_etage only this one is open (without close the other group if this one is already closed)
I see that we can use condition in action but according to the documentation, if one condition is not true, all followed actions are stopped so we cannot use parallel conditions
condition:
- after: '16:00:00'
condition: time
- condition: and
conditions:
- condition: or
conditions:
- condition: state
state: open
- condition: state
state: open
can be simplified to this:
condition:
- after: '16:00:00'
condition: time
- condition: or
conditions:
- condition: state
state: open
- condition: state
state: open
Next, is it really a problem to close a cover that is not open? I don’t use cover entities, so I’m not sure. What happens (that you don’t want to happen) if you just have the automaton close both covers regardless of their current state? E.g.:
- below: '100'
for: '1200'
condition:
- after: '16:00:00'
condition: time
- data:
entity_id:
- cover.volets_rdc
If you really need to only close the cover or covers that are currently open, then probably the easiest way to do that is to have one automation per cover:
- alias: Fermeture volets automatique rdc
- below: '100'
for: '1200'
condition:
- after: '16:00:00'
condition: time
- condition: state
state: open
- data:
entity_id:
- cover.volets_rdc
and
- alias: Fermeture volets automatique etage
- below: '100'
for: '1200'
condition:
- after: '16:00:00'
condition: time
- condition: state
state: open
- data:
entity_id:
@pnbruckner: I want to avoid to enable switch when the cover is already close (or open)…
@Mutt do you have an example to do this? The documentation is not clear… I want to avoid to use one automation by cover (if I do it, I need more 16 automations only to manage cover)
What switch? I guess maybe you’ve only describe a piece of what you’re ultimately trying to do. It’s a little hard to make useful suggestions when you only explain part of the scenario.
In any case, ignoring your ultimate goal, if you want to have a conditional step in the action part of an automation (or in a script, which is basically the same thing), you can’t. HA’s script implementation does not have such a feature. However, you could put each conditional step into its own script, and then call them all from the automation.
We have 2 switch: one for bedroom, one for kitchen (opened for both)
I close manually a cover
New status: cover bedroom is open, cover kitchen is closed
The automation detect now a low luminosity & close these 2 covers: currently the 2 switchs are enabled (I want only close the cover currently open and no action on the cover closed). (unless create 6 automations (1 for manually (via aquara switch), 1 for close auto (luminosity), 1 for open manually (via aquara switch) for only 2 switchs). It’s pitty that we cannot simply add a condition in the action sequence.
Thanks for the script idea, seems good. I will check.
