Action Smart (LSC smart connect) works with TUYA integration
Is there a way to have and use the motion sensor and the phone option of the camera in HA?
I am using the (horrible) LSC App, because it offers european privacy protection security.
When I try to use the official tuya integration after scanning the QR-Code in LSC I receive a message saying that I should use the appropriate App - probably the original Tuya-App that is forbidden for me due to privacy issues.
Any idea how to fix this?
Thanks mate! For all german users which buy products from “action” market its also working for the brand “battletron”
Hi Phacra,
I followed your info to add the LSC Smart syncbox to HA.
In the Tuya app I have all the parameters but in HA the unit was easily found but I only have the option ON/OFF and color change but all the other options are not visible. Am I doing wrong or do I need to make additional settings??
Thanks,
Rolof
hi,
Tuya asks for a User code… but where do I find it?
edit… Found it!
But in Home Assistant, I cannot find the buttons for Pan/tilt. Do I something wrong?
This would be nice to know!
just installed the hdmi sync box and also only on/off and color :frowning: No other option in HA available. Nice would be the TV Scene combination.
I bought a video door bell from action and i connect first on LSC app. After a while i remove it from lsc to try to put in tuya app in order to have it on ha. But i can’t add it anymore on tuya or LSC. I tried to reset it pressing 3 seconds on reset button, i heard noise, the led blink on/off/on with a sound and that’s all. I don’t know if the reset is good. Any suggestion welcome
For me it work only partially.
I get a preview image in the “Media”/“Camera” section as well as I get one when I add a camera view anywhere.
But I get no live video from the camera when I click on the Image. No video is played, just a white screen with the video controls.
My MJPEG-Cameras working without any problems.
I am running a “LSC PTZ Camera Dual Band”, the camera is added using the standard Tuya addin, PTZ controls is realized using Local Tuya.
Going to order 2 to replace my stupid 2 led behind my rear front and left speaker towers. This is also working with tuya but at least 7 years old and the connect gives up a bit. sometimes i have to gently push 1 led to get it to function. seeyin the happeniss of people here im surely going to give it a shot so i can also manage them seperately instead how its now, 2 les connected to a single (hubbish receiver)
So for people with Mikrotik wifi, I had to look for the correct 2ghz settings. And this works for me:
/interface wifi channel
add band=2ghz-n comment=https://en.wikipedia.org/wiki/List_of_WLAN_channels disabled=no frequency=2412,2437,2462 name=all2ghz skip-dfs-channels=all width=20mhz
/interface wifi security
add authentication-types=wpa2-psk disable-pmkid=no disabled=no encryption=ccmp,gcmp ft=no ft-over-ds=no name=older_iot_devices
/interface wifi configuration
add comment="older iot devices" country=Netherlands disabled=no mode=ap name=iot security=older_iot_devices security.connect-priority=0 .ft=no .ft-over-ds=no ssid=iot.maas-martin.nl
Are there any fix on this?
I have a smart GU10 light from action. I added correctly on tuya app and can change color/brightness and so on. But in the HA tuya integration I can only turn on and off....is there any fix?
Hallo, könnte bitte der TExt angepasst werden, wenn ich ein neues Gerät über die Tuya Integration einfügen möchte. Das Wort "Einstellungen" finde ich nicht in der Tuya App.
" Gib deinen Smart Life- oder Tuya Smart-Benutzercode ein.
Du findest diesen Code in der Smart Life-App oder Tuya Smart-App im Bildschirm Einstellungen → Konto und Sicherheit und gib den im Feld Benutzercode angezeigten Code ein. Beim Benutzercode muss die Groß-/Kleinschreibung beachtet werden, achte darauf, ihn genau wie in der App angezeigt einzugeben."
Danke
Gruß
Carsten
Nachtrag, so ist es korrekt:
Profil -> Einstellungssymbol rechts oben -> Benutzerkonto
Danke.
