@robbiet480 I’ve followed your instructions on how to set up actionable notifications but it doesn’t appear to be working for me. Running the latest beta seed and iOS 10.3.
Here is the automation which should fire the notification. Notice I try two separate ways to receive the notification. The second option says press for more but the buttons don’t show up.
@robbiet480 not sure why the forum formatted it that way. It was correct in my yaml file. I copy pasted your code and still i only get the notification and not the actionable buttons. Not sure what i’m doing wrong.
I’m also having trouble getting actionable notifications to work. I have copied the example config exactly and modified as needed, but no action buttons are showing on the notification. I have updated push settings in the app as well.
iOS 10.2.1
One interesting note is that adding the category results in a duplicated notification.
Make sure you hit Update Push Settings in the app after restarting Home Assistant. If it still isn’t working then try restarting the device. Sounds crazy I know but Apple sometimes fails to register the notification content extensions and will only attempt a re-register on restart.
I am brand new at Home Assistance, not sure if this is going to help.
I spent the last two days trying to get the buttons to show up, but all I got was just the message and no buttons. Turned out it was there the whole time. The problem was I was clicking on the notification instead of sliding it to the left (if phone is locked) or pulling down (if phone is unlock). Clicking it will open up the app and does nothing. It would be nice if the action will pop up in the app as well.
Thanks man. I’m using HA for quite a while now, but I was banging my head why I couldn’t make this happen. Tried all sorts of configs, and it turned out I did every perfect, but no buttons.
I am having the same issues. Tried Swiping left, right, up, and down. Pushed harder on the notification. Still no button. Reset HA, restarted iphone, update push settings.
