Hi guys.
I use iOS and the Home Assistant Companion app for push notifications.
I created some widgets using iOS “Commands” app, these widgets call a script (non automation) on Home Assistant, for example “Disable Alarm” and everything works fine.
Now I would like to add the ability to select a confirmation in the notification,
for example, I select the widget command to deactivate the alarm, the command calls the script on HA, the HA notification on iOS arrives asking me if I want to confirm the action. If I confirm it runs the script on HA, otherwise it does nothing.
Unfortunately I can’t get this, can you help me? Thanks
The script to call is script.0000_deactivate_alarm, the notification service is notify.mobile_app_nanu
