Actionable notification works intermittently
I’ve set up an actionable notification when I detect motion which includes a snapshot from BI. It works great, however I noticed that after some time I stop receiving the picture in the notification. If I open the mobile app I start receiving the picture again but after a few hours it stops.
Has anyone seen this behavior before ? I’ve confirmed the snapshot is stored every time so it’s definitely the mobile app not retrieving it…
Look at the app configuration logs it will show the notification details to see what happened.
Do you mean the standard logs in HA under configuration ? If so, there’s no log entries when I get a notification without the picture.
no in the app, go to app configuration and there is a logs section there…make sure to reproduce the issue before you look at the device logs.
Thanks, I took a look but I don’t see any errors thrown. It’s clear that the notification isn’t the same though. 07:52:00 is the initial trigger that did not work. 07:55:17 is the one that worked.
I’m seeing a lot of certificate chaining issues (I use an external cert) Is it possible my android device isn’t trusting the certificate ? Not sure if this could account for the different behavior when the app is opened or not ?
09-07 07:52:00.125 32179 12802 D UrlRepository: localUrl is: false and usesInternalSsid is: false
09-07 07:52:00.195 32179 12785 I WM-WorkerWrapper: Worker result SUCCESS for Work [ id=201c0359-ce9c-45b2-88bd-8670a7ad617c, tags={ io.homeassistant.companion.android.sensors.SensorWorker } ]
09-07 07:52:00.197 32179 32179 I WM-SystemFgDispatcher: Stopping foreground service
09-07 07:52:00.203 32179 32179 D ConnectivityManager: unregisterNetworkCallback; CallingUid : 10343, CallingPid : 32179
09-07 07:52:00.327 32179 32179 I SurfaceView: onWindowVisibilityChanged(8) false android.view.SurfaceView{2ffc3bf G.E...... ......I. 0,0-0,0} of ViewRootImpl@eeda07e[WebViewActivity]
09-07 07:52:00.333 32179 32179 I ViewRootImpl@eeda07e[WebViewActivity]: Relayout returned: old=(0,0,1080,2220) new=(0,0,1080,2220) req=(1080,2220)8 dur=4 res=0x5 s={false 0} ch=true
09-07 07:52:00.338 32179 32179 I ViewRootImpl@eeda07e[WebViewActivity]: stopped(true) old=false
09-07 07:52:00.338 32179 32179 I SurfaceView: windowStopped(true) false android.view.SurfaceView{2ffc3bf G.E...... ......I. 0,0-0,0} of ViewRootImpl@eeda07e[WebViewActivity]
09-07 07:52:00.353 32179 32179 I ViewRootImpl@eeda07e[WebViewActivity]: Relayout returned: old=(0,0,1080,2220) new=(0,0,1080,2220) req=(1080,2220)8 dur=4 res=0x5 s={false 0} ch=false
09-07 07:52:00.673 32179 32179 I ViewRootImpl@f3cf573[SettingsActivity]: ViewPostIme pointer 0
09-07 07:52:00.840 32179 32179 I ViewRootImpl@f3cf573[SettingsActivity]: ViewPostIme pointer 1
09-07 07:52:01.342 32179 32179 I ViewRootImpl@f3cf573[SettingsActivity]: ViewPostIme pointer 0
09-07 07:52:01.468 32179 32179 I ViewRootImpl@f3cf573[SettingsActivity]: ViewPostIme pointer 1
09-07 07:52:05.149 32179 32179 I ViewRootImpl@f3cf573[SettingsActivity]: ViewPostIme pointer 0
09-07 07:52:05.280 32179 32179 I ViewRootImpl@f3cf573[SettingsActivity]: ViewPostIme pointer 1
09-07 07:52:10.937 32179 32179 I ViewRootImpl@f3cf573[SettingsActivity]: ViewPostIme pointer 0
09-07 07:52:11.078 32179 32179 I ViewRootImpl@f3cf573[SettingsActivity]: ViewPostIme pointer 1
09-07 07:52:12.914 32179 32179 I ViewRootImpl@f3cf573[SettingsActivity]: ViewPostIme pointer 0
09-07 07:52:13.017 32179 32179 I ViewRootImpl@f3cf573[SettingsActivity]: ViewPostIme pointer 1
09-07 07:52:13.044 32179 32179 D ScrollView: initGoToTop
09-07 07:52:13.078 32179 32179 I ViewRootImpl@f3cf573[SettingsActivity]: Relayout returned: old=(0,0,1080,2220) new=(0,0,1080,2220) req=(1080,2220)0 dur=7 res=0x1 s={true 532384907264} ch=false
09-07 07:52:13.083 32179 13013 D LogcatReader: Read logcat for pid 32179
09-07 07:52:13.197 32179 13013 D LogcatReader: Done reading logcat for pid 32179
09-07 07:52:13.320 32179 32179 D ScrollView:  onsize change changed
09-07 07:52:13.405 32179 32179 D InputMethodManager: prepareNavigationBarInfo() DecorView@57a94a5[SettingsActivity]
09-07 07:52:13.405 32179 32179 D InputMethodManager: getNavigationBarColor() -15658735
09-07 07:52:13.405 32179 32179 V InputMethodManager: Starting input: tba=io.homeassistant.companion.android ic=null mNaviBarColor -15658735 mIsGetNaviBarColorSuccess true , NavVisible : true , NavTrans : false
09-07 07:52:13.405 32179 32179 D InputMethodManager: startInputInner - Id : 0
09-07 07:52:13.405 32179 32179 I InputMethodManager: startInputInner - mService.startInputOrWindowGainedFocus
09-07 07:52:13.407 32179 32179 D InputTransport: Input channel destroyed: 'ClientS', fd=305
09-07 07:52:16.543 32179 32179 I ViewRootImpl@f3cf573[SettingsActivity]: ViewPostIme pointer 0
09-07 07:52:16.948 32179 32179 I ViewRootImpl@f3cf573[SettingsActivity]: ViewPostIme pointer 1
09-07 07:52:20.502 32179 32179 I ViewRootImpl@f3cf573[SettingsActivity]: ViewPostIme pointer 0
09-07 07:52:21.130 32179 32179 I ViewRootImpl@f3cf573[SettingsActivity]: ViewPostIme pointer 1
09-07 07:52:24.800 32179 32179 I ViewRootImpl@f3cf573[SettingsActivity]: ViewPostIme pointer 0
09-07 07:52:24.994 32179 32179 I ViewRootImpl@f3cf573[SettingsActivity]: ViewPostIme pointer 1
09-07 07:52:25.960 32179 32179 I ViewRootImpl@f3cf573[SettingsActivity]: ViewPostIme pointer 0
09-07 07:52:26.122 32179 32179 I ViewRootImpl@f3cf573[SettingsActivity]: ViewPostIme pointer 1
09-07 07:52:27.058 32179 32179 I ViewRootImpl@f3cf573[SettingsActivity]: ViewPostIme pointer 0
09-07 07:52:27.190 32179 32179 I ViewRootImpl@f3cf573[SettingsActivity]: ViewPostIme pointer 1
09-07 07:52:29.918 32179 32179 I ViewRootImpl@f3cf573[SettingsActivity]: ViewPostIme pointer 0
09-07 07:52:30.085 32179 32179 I ViewRootImpl@f3cf573[SettingsActivity]: ViewPostIme pointer 1
09-07 07:52:30.616 32179 32179 I ViewRootImpl@f3cf573[SettingsActivity]: ViewPostIme pointer 0
09-07 07:52:30.779 32179 32179 I ViewRootImpl@f3cf573[SettingsActivity]: ViewPostIme pointer 1
09-07 07:52:32.224 32179 32179 I ViewRootImpl@f3cf573[SettingsActivity]: ViewPostIme pointer 0
09-07 07:52:32.382 32179 32179 I ViewRootImpl@f3cf573[SettingsActivity]: ViewPostIme pointer 1
09-07 07:52:32.857 32179 32179 I ViewRootImpl@f3cf573[SettingsActivity]: ViewPostIme pointer 0
09-07 07:52:33.006 32179 32179 I ViewRootImpl@f3cf573[SettingsActivity]: ViewPostIme pointer 1
09-07 07:52:34.279 32179 32179 I ViewRootImpl@f3cf573[SettingsActivity]: ViewPostIme pointer 0
09-07 07:52:34.418 32179 32179 I ViewRootImpl@f3cf573[SettingsActivity]: ViewPostIme pointer 1
09-07 07:52:34.855 32179 32179 I ViewRootImpl@f3cf573[SettingsActivity]: ViewPostIme pointer 0
09-07 07:52:35.003 32179 32179 I ViewRootImpl@f3cf573[SettingsActivity]: ViewPostIme pointer 1
09-07 07:52:40.150 32179 32179 I ViewRootImpl@f3cf573[SettingsActivity]: ViewPostIme pointer 0
09-07 07:52:40.175 32179 32179 I ViewRootImpl@f3cf573[SettingsActivity]: ViewPostIme pointer 1
09-07 07:52:40.185 32179 32179 D LogFragment: Click on share logs without WRITE_EXTERNAL_STORAGE permission
09-07 07:55:17.034 32179 13013 D UrlRepository: localUrl is: false and usesInternalSsid is: false
09-07 07:55:17.127 32179 13013 D LocBroadcastReceiver: Location update sent successfully
09-07 07:55:38.361 32179 13013 D NextAlarm: No alarm is scheduled, sending unavailable
09-07 07:55:38.431 32179 13013 D UrlRepository: localUrl is: false and usesInternalSsid is: false
09-07 07:56:32.554 32179 16039 D MessagingService: From: 331041709873
09-07 07:56:32.555 32179 16039 D MessagingService: Message data payload: {image=https://bulldog.iwearbibs.com:8123/local/snapshot_doorbell.jpg, title=ALERT, message=Front Door Alert, action_1_title=Open Video, action_1_key=URI, action_1_uri=/lovelace/video}
09-07 07:56:32.571 32179 32179 D MessagingService: Creating notification with following data: {image=https://bulldog.iwearbibs.com:8123/local/snapshot_doorbell.jpg, title=ALERT, message=Front Door Alert, action_1_title=Open Video, action_1_key=URI, action_1_uri=/lovelace/video}
09-07 07:56:32.617 32179 32179 D UrlRepository: localUrl is: false and usesInternalSsid is: false
09-07 07:56:32.617 32179 32179 D UrlRepository: Using external URL
09-07 07:56:32.624 32179 13013 I System.out: (HTTPLog)-Static: isSBSettingEnabled false
09-07 07:56:32.764 32179 32179 D MessagingService: Show notification with tag "null" and id "-1071779904"
09-07 07:56:48.408 32179 16039 D MessagingService: From: 331041709873
09-07 07:56:48.408 32179 16039 D MessagingService: Message data payload: {image=https://bulldog.iwearbibs.com:8123/local/snapshot_doorbell.jpg, title=ALERT, message=Front Door Alert, action_1_title=Open Video, action_1_key=URI, action_1_uri=/lovelace/video}
09-07 07:56:48.411 32179 32179 D MessagingService: Creating notification with following data: {image=https://bulldog.iwearbibs.com:8123/local/snapshot_doorbell.jpg, title=ALERT, message=Front Door Alert, action_1_title=Open Video, action_1_key=URI, action_1_uri=/lovelace/video}
09-07 07:56:48.430 32179 32179 D UrlRepository: localUrl is: false and usesInternalSsid is: false
09-07 07:56:48.430 32179 32179 D UrlRepository: Using external URL
09-07 07:56:48.432 32179 13013 I System.out: (HTTPLog)-Static: isSBSettingEnabled false
09-07 07:56:48.479 32179 32179 D MessagingService: Show notification with tag "null" and id "-1071764069"
09-07 07:56:57.751 32179 32179 D SensorReceiver: Sensor is_interactive corresponding to received event android.intent.action.SCREEN_ON is disabled, skipping sensors update
according to the logs there was no notification received, I only see 2 notifications one at 7:56:32 and 7:56:48
if it was a cert issue then you wouldnt be able to access HA using the app.
If you had encountered an error I would expect to see an error similar to this line
With that said I have seen some users on certain android devices who found an issue showing an image alongside actionable notification, I believe it was a MIUI device and the issue was resolved via a system update on that device.
Thanks,
I ran another test and it’s really strange I get a notification just not the image. But like you said in the logs I see zero entry that indicates a message was sent. I suspect I should be seeing something
I do see a bunch of untrusted chain errors whenever I get an unsuccessful message. My cert is about to roll over so I think I’m going to fix those first. Is it possible the app or android o/s does not have the proper trusted CA cert for my certification signing authority ? Should I issue a new cert from a different 3rd party CA ?
09-09 09:12:07.878 10297  8892 E CONSCRYPT: ------------------Untrusted chain: ----------------------
09-09 09:12:07.878 10297  8892 E CONSCRYPT: == Chain0 ==
09-09 09:12:07.878 10297  8892 E CONSCRYPT:  Version:   3
09-09 09:12:07.878 10297  8892 E CONSCRYPT:  AuthorityKeyIdentifier:   418301680148d8c5ec454ad8ae177e99bf99b05e1b8018d61e1
09-09 09:12:07.878 10297  8892 E CONSCRYPT:  SubjectKeyIdentifier:   4160414298a031662faf7da4c1bce2c5361cdc64fd2be3c
09-09 09:12:07.878 10297  8892 E CONSCRYPT:  Serial Number:   ec58074d80cbd6ff15e0fd608eda81cb
09-09 09:12:07.880 10297  8892 E CONSCRYPT:  SubjectDN:   CN=bulldog.iwearbibs.com
09-09 09:12:07.880 10297  8892 E CONSCRYPT:  IssuerDN:   CN=Sectigo RSA Domain Validation Secure Server CA, O=Sectigo Limited, L=Salford, ST=Greater Manchester, C=GB
09-09 09:12:07.896 10297  8892 E CONSCRYPT:  Get not before:   Sun Oct 04 20:00:00 EDT 2020
09-09 09:12:07.896 10297  8892 E CONSCRYPT:  Get not after:   Tue Oct 05 19:59:59 EDT 2021
09-09 09:12:07.896 10297  8892 E CONSCRYPT:  Sig ALG name:   SHA256withRSA
yea android can be picky about that, try a more popular known service maybe?
Ended up generating a cert using Let’s Encrypt. Seems to have done the trick.
