Actionable Notifications Aren't Showing on iPhone
I’m stumped. Could someone help me work out why actionable notification buttons aren’t appearing on my iPhone please?
Here is the code:
ios:
  push:
    categories:
      - name: Car Alarm
        identifier: 'car_alarm'
        actions:
          - identifier: 'DISABLE_ALARM'
            title: 'Disable Car Notifications'
            activationMode: 'background'
            authenticationRequired: true
            destructive: true
            behavior: 'default'
          - identifier: 'ENABLE_ALARM'
            title: 'Enable Car Notifications'
            destructive: false
            behavior: 'default'
automation:
  - alias: 'test ios 2'
      - platform: state
        entity_id: binary_sensor.window_spare_sensor_s2_contact
        to: 'on'
      - service: notify.mobile_app_iphone
          title: "Testing"
          message: "Test alarm message!"
            push:
              category: "car_alarm"
            action_data:
              entity_id: input_boolean.car_disable_notification
  - alias: Disable Car Alarm
      - platform: event
        event_type: ios.notification_action_fired
        event_data:
          actionName: DISABLE_ALARM
      - service: input_boolean.turn_off
Screenshots of the App settings, showing that I have imported the push configuration:
Having a similar issue with a door lock. App shows I’ve imported the push settings. But buttons never show!
try this i just tested and is working and if you iphone supports 3d touch press on the notification to show the two actions if your iphone does not supports 3d touch i think you have to swap left or right i hope it helps
ios:
  push:
    categories:
      - name: Car Alarm
        actions:
            destructive: true
            behavior: 'default'
            destructive: false
            behavior: 'default'
automation:
      - platform: state
        to: 'on'
          title: "Testing"
            push:
      - platform: event
        event_data:
@kem thank you for your help and suggestion.
It’s certainly strange as I still can’t make the notification show any buttons, even after doing 3D Touch on the message and using the same code you tested above (though I couldn’t see any difference between the two?). I must be doing something else wrong. :thinking:
When you go in the in-app notification editor (the second screenshot in OP) towards the bottom right corner of the screen is an “eye” icon.
Tapping that sends a preview notification, and I’ve found that can sometimes get the buttons to show up initially. Maybe you could try that a few times and hopefully it works.
