Iām having the same issue with my setup.
Turning off the input_boolean
is in the automation, lines 120 and 121:
entity_id: !input 'trigger_entity'
You might try commenting out those lines or deleting them and see if the automation still works for you. I havenāt tried it myself because Iām using a boolean that I want turned off.
That did the trick. Works like I was expecting now.
Great job,thanks!
Found a typo in action_2uri:
update to
action_2_uri:
name: URI for action 2 (Optional)
description: Optional URI for the second action
default: ""
really cool, thanks
I thought Iād mention in this thread, I used bits of this blueprint to make my own! Thanks for your awesome blueprint!
Hey, Iām looking at using your blueprint to notify on activity detected by a camera. Great job on that, thanks for sharing!
I changed the trigger to an input_text instead of an input_boolean, that works well. That input_text captured the message sent by the camera on detection. Do you know if there is a way to have that message as notification title? Iāve tried to use {{ trigger.to_state }}
without successā¦ removing the brackets doesnāt work either, template isnāt resolvedā¦
Any help would be welcomed! cheers
I canāt help with your problem explicitly, but {{ trigger.to_state }}
normally is {{ trigger.to_state.state }}
It works! I love you so much
thanks for that blueprint. But can it be, that it will only work with the full version of the android app from PlayStore? I am using the version from F-Droid. This means also the normal notifications wonāt work at all.
What I tried by now:
- create boolean helper
- create two automations
2.1 just a test for turning the boolean on manually
2.2 added the boolean, my device and app://net.programmierecke.radiodroid2
But in fact absolutelly nothing happens. So I assume I need to use the full version. If this is correct, can you mention that please in thr RTFM? Because this saves time for ppl who dont want to use gapps on their phones. But it would be nice to have such a feature also with the version from F-Droid
As for example the service ānotify.mobile_app_ā does not exist on the ālightā version.
Ref: https://github.com/home-assistant/android/issues/1367
cheers
fb
Thatās because the notifications for the companion app are using Google services to deliver these to your phone. Without the Google Play Framework, it is not possible to use the notifications in Android.
If you know a better way, let us know, Iād be very interested in avoiding these Google servicesā¦
it is in the companion documentation: Android Flavors | Home Assistant Companion Docs
and also mentioned on F-Droid: Home Assistant | F-Droid - Free and Open Source Android App Repository
hi,
so my question was answerd indirectly. Yes, the full version is needed as well. And yes, also just using the full version without gapps wonāt lead to anywhere because google services are needed.
Well. I am not really a coder. But Signal and Telegram are also working without gapps. So maybe the same procedure would work here as well.
Jump over to the Android companion app thread and request the notifications on the frdoid app there. I will say, the developer has made it very clear he will not support alternative notifications though, unfortunately
We never said that, we said that we will accept PRās on it and that a viable solution will still require a server setup based on what we have seen. We would love to move away from firebase but it requires a lot of changes and its not simple. Its going to require core changes as well. Firebase just makes life easier to implement which is why it exists today. The enhancement request on github was not closed either so not sure where you got it from that it wouldnāt be supported. We are also open source so anyone can come along and add submit a PR. Whatever we consider it will be benefit all users and not just the minimal version.
Newbie question - to get actions to work, does the phone need to be able to access Home Assistant? for example, if HA is not configure for remote access and the Android device is not connected to the homeās WiFi network - will actions work?
Actions need to send data back home otherwise the automation wonāt trigger
Fantastic Blueprint thank you. I have a question though: I create an automation with two action, I receive the notification but I can run just one of the actions because the notification disappear. I tried the persistent notification but without luck. How can I click on more than 1 action on the notification?
Use the sticky setting so it doesnāt disappear when you tap on it.
https://companion.home-assistant.io/docs/notifications/notifications-basic#sticky-notification
how would you apply that?? I couldnāt get it to work. I also tried persistent notifications but they donāt swipe away. see below
alias: Actionable Alert - Garage Open
description: ''
use_blueprint:
path: vorion/actionable-notifications-for-android.yaml
input:
notify_device: f4042851132f11ebbe446f1efb348754
trigger_entity: input_boolean.garage_door
notification_title: Garage Door Open
persistent_notification: "false"
sticky: "true"
action_1_title: Close Garage Door
first_action:
- service: cover.close_cover
entity_id: cover.garage_door_controller
action_2_uri: /lovelace-cameras/garage
action_2_title: Garage Camera
my phone
