Get a fancy notification when there is an update available to home assistant!
If you're using an Android 8.0+ device, this blueprint will give you fancy update notifications like this one!
But the best part of all, what makes this blueprint the better choice over others available (imo), is that you can update your notifications settings for this specific notification.
And it can also group up with other similar notifications if you have multiple update notifiers
Expanded
Oh, and for good measure, I added a toggle (off by default) to go directly to the Home Assistant Podcast episodes list so I can listen to this release's podcast episode before I install it.
Blueprint Code
blueprint:
name: Home Assistant Update Notification for Android
description: Send a notification when there's an update availiable for Home Assistant
domain: automation
input:
updater:
description: "The sensor which indicates if there's an update. Default is 'binary_sensor.updater'"
default: binary_sensor.updater
selector:
entity:
domain: binary_sensor
notify_device:
name: Device to notify
description:
Device needs to run the official Home Assistant app to receive
notifications
selector:
device:
integration: mobile_app
notification_title:
description: 'What would you like to appear as the title of the notification on your device? If you put "{{ newest_version }}" in your message it will be replaced with the actual version number in your notification'
default: Upgrade time!
notification_message:
description: 'What would you like the message in your notification to be? If you put "{{ newest_version }}" in your message it will be replaced with the actual version number in your notification'
default: Home Assistant {{ newest_version }} is available
category:
description: "Devices running Android 8.0+ are able to create and manage notification channels on the fly. Once a channel is created you can navigate to your notification settings and you will find the newly created channel, from there you can customize the behavior (like notication sounds, etc) based on what your device allows."
default: Home Assistant Updates
color:
description: "You can set the color of the notification, you can use either the color name or the hex code."
default: homeassistant
importance:
name: Notification importance
description:
When you are setting the channel for your notification you also
have the option to set the importance for the channel per notification. Possible
values for this property are high, low, max, min and default.
default: high
group:
description:
Setting a notifiction group will group it with other notifications
of the same group. Useful to be able to group other update notifications together.
default: Available Updates
delay:
description: Wait before sending the notification
default:
selector:
number:
min: 0.0
max: 60.0
unit_of_measurement: seconds
mode: slider
step: 1.0
clickAction:
description: "Clicking on the notification takes you where?"
default: "https://my.home-assistant.io/redirect/supervisor/"
include_release_notes:
name: Include release notes
description: 'Add a "release notes" button to the notification'
selector:
boolean: {}
default: true
include_hasspodcast:
name: Include HassPodcast link
description: "Add a HassPodcast button to the notification"
selector:
boolean: {}
default: false
source_url: https://gist.github.com/fortepc/042c8b3e77cc2870d803e886cc895f34
platform: state
entity_id: !input "updater"
to: "on"
for: !input "delay"
mode: restart
max_exceeded: silent
variables:
updater: !input "updater"
newest_version: "{{ states[updater].attributes.newest_version }}"
release_notes: "{{ states[updater].attributes.release_notes }}"
include_release_notes: !input "include_release_notes"
include_hasspodcast: !input "include_hasspodcast"
color: !input "color"
category: !input "category"
group: !input "group"
importance: !input "importance"
notify_device: !input "notify_device"
notification_title: !input notification_title
notification_message: !input notification_message
action_1_title: "{% if include_release_notes %}Release Notes{% endif %}"
action_1_uri: "{% if include_release_notes %}{{ release_notes }}{% endif %}"
action_2_title: "{% if include_hasspodcast %}HassPodcast{% endif %}"
action_2_uri: "{% if include_hasspodcast %}https://hasspodcast.io/episodes{% endif %}"
clickAction: !input "clickAction"
# Send actionable notification
- domain: mobile_app
type: notify
device_id: !input notify_device
title: "{{ notification_title }}"
message: "{{ notification_message }}"
persistent: "{{ persistent_notification }}"
color: "{{ color }}"
channel: "{{ category }}"
group: "{{ group }}"
importance: "{{ importance }}"
clickAction: "{{ clickAction }}"
actions: >
{% set titles = [action_1_title, action_2_title, action_3_title] %}
{% set uris = [action_1_uri, action_2_uri, action_3_uri] %}
{% set actions = namespace(data = []) %}
{% for title in titles %}
{% if title|length %}
{% set uri = uris[loop.index - 1] %}
{% set action_name = "action" + loop.index|string %}
{% set action = {
"action": "URI" if uri|length else action_name,
"title": title,
"uri": uri
{% set actions.data = actions.data + [action] %}
{% endif %}
{% endfor %}
{{ actions.data }}
Credit
To give credit where it's due, I didn't come up with this on my own. I was using this blueprint but I wanted to tweak a few things, most importantly I wanted to be able to customize the notification sound to be different than my other notifications, so I needed to give it support for notification categories & groups. I also wanted to be able to make the release notes an action button on the notification instead of replacing the notification's click action
That's where this blueprint came in, I was struggling to figure out how to make all the syntax work with the optional action button, until I eventually just copied the action button section entirely from this blueprint.
