Activate a scene inside a script
I’m aware now that you cannot activate a script from inside a scene. Which is a bummer because some of my lights are controlled via the Harmony Hub send_command.
I tried switching my entire lighting scenes over to scripts. It works, but there’s a large delay compared to using scenes. Plus, it’s a pain to set switches and lights using scripts.
So I tried this:
  scene_starlight:
    alias: Starlight
    sequence:
      - service: remote.send_command
          entity_id: remote.harmonyhub
          device: 41760987
          command: Light1
      - service: scene.turn_on
          entity_id: scene.starlight
However, this does not seem to work. Am I just screwing up the syntax, or can scenes not be turned on from within a script?
Try:
I run scripts as part of scenes, like this:
- scene:
  - name: Bedtime
    entities:
      light.landing_light:
        state: on
        transition: 2
        brightness: 1
      light.office_light:
        state: off
        transition: 2
      light.kitchen:
        state: off
        transition: 2
      light.tv_light:
        state: off
        transition: 2
      script.living_room_off_delayed:
        state: on
With the script code elsewhere (in a different .yaml file). Is this the kind of thing you wanted to do?
I had that originally. But I can give it another shot. It seemed like other commands wanted it to fall under Data:
Wait, so you CAN do that? If so, that’s great news. I’ll have to give that a try tonight!
Yes, I have a few scenes that run scripts in them :+1:t3:
do it still working?
It stopped working here.
You can no longer call scripts from scenes.
Are there any workarounds, or do we have to just change our setups and remove all scripts from scenes?
You have to remove all scripts from scenes.
OK, thanks for the confirmation :+1:t3:
I created a input_boolean which triggers the script in an automation. That worked for me! :slight_smile:
In the scene:
scene:
  - name: my scene
    entities:
      input_boolean.random_color: on
Yea, I have a few of those.
I ended up recreating my scenes with scripts.
