Activate a scene with climate
I can’t activate a scene with a climate entity.
Here is my automation with a wiser climate entity.
alias: test scene
description: ""
trigger: []
condition: []
  - action: scene.create
    metadata: {}
      scene_id: test
      snapshot_entities:
        - climate.wiser_chambre_d_amis
  - action: scene.turn_on
    metadata: {}
      entity_id: scene.test
mode: single
When a do the scene.turn_on, i get
must contain at least one of temperature, target_temp_high, target_temp_low.
Do you have an idea why ? and how to fix this ?
I’m also having this problem. I have no idea why it is happening. It only seems to happen when I have thermostats included that are currently set to off. Ideally, if a scene, if the thermostat is off when a scene is created, it should be when the scene is activated.
