noob here
any chance I can get a for dummies walk through to toggle the state of a GPIO on a remote webiopi garage door remote. I found the BCM GPIO I want to toggle on the remote webiopi just need some help making the config yaml work, then send the commands to toggle.
so my garage door is a single button. Press = go up, another press = stop , another press = go down. Simple wifi controlled relay on a RPI, works a treat with web interface.
I want to bring a switch into HA. on MQTT i have to send the command twice, essentially open the relay then close again to get one for the above ‘presses’ to work. 6 cycles if I want to open, stop mid way and then close again. Any ideas how I can send the command of open , then reset the relay?
I know this is an old inquiring on an old thread (ha!) but FYI this component doesn’t map to webiopi well. As far as I have gathered webiopi does not use a restAPI in the same manner. You post to a different URL to set the values than you do to get the value. I’m still searching for the best solution. A few just using switch components are possible.
