I made a RF/IR to MQTT gateway following the great project of 1technophile you can find here:
It really works great, I can control 433 outlets, stuff with IR remote, a lot of stuff.
I have a couple of RF remote that are received perfectly by the OpenMQTTGateway, I connected to some switch and turn on and off lights, but I wanted to use them to activate scenes.
I did that creating mqtt switches in HA and using them as trigger in an automation to recall a scene, but this use actually 2 buttons on the remote, to turn on and off each scene. It would be much better if I could use the 6 buttons on the remote, each sending a different RF code, to recall 6 different scenes, but I don’t know how to achieve that.
This is my config section to create the switches:
- platform: mqtt
state_topic: "home/433toMQTT" # defined in OpenMqttGateway
command_topic: "home/commands/MQTTto433/PLSL_345/433_1" #parameters for receiving RF
payload_on: "1234567" # code received when I push button 1 on remote
payload_off: "7654321" # code received when I push button 2 on remote
optimistic: false
retain: true
And this is the automation I use to recall a scene:
# recall the scene "full" when switch is turned on
- alias: 'Remote Full'
platform: state
entity_id: switch.scene_full
to: 'on'
- service: scene.turn_on
entity_id: scene.full
# recall a "all off" scene when the switch is turned off
- alias: 'Remote Off1'
platform: state
to: 'off'
entity_id: scene.all_off
This code works great with outlet, if I push on or off from the remote the HA switch update, I can control by HA, perfect, but I don’t know how to make it a momentary switch to activate a scene.
What I mean is that, as know, I can’t assign a scene for each button of the remote, because switches in HA need to be on to be turned off, so I have to push on the buttons like a pianist to reach the scene I want, with psychedelic effects in my house !
Any advice?
Of course I commented all the section I used before in configuration.yaml and automation.yaml, but it doesn’t work.
Also, and this looks weird to me, it mess up my Automation section in main page:
In my eralier configuration, I took the instruction to write in config from the page of OpenMqttGateway, and it seems to need these two info, state_topic and command_topic, but I guess I’m too ignorant to understand
I just tried your automation on my test system, and it seemed to work fine, so I don’t know why you are not getting a trigger.
I’m afraid I can’t help you with the front end - I don’t really use it.
The openMqttGateway just detects the 433 MHz signal from the button press and generates an MQTT message from it - I have been using it for over a year.
The switch needs a state_topic and a command_topic, but this doesn’t really correspond to your usage. I think you just want something to change when you press the button, and your automation does that - at least on my system.
Edit:
I think I see the problem. The OpenMQTTGateway sends the messages on the topic home/433toMQTT. It is messages to the gateway that use the other topic. You need to change your automation to
IT WORKS!
You’re great man, I was trying to do this but, shame on me, I know too little of the MQTT to understand correctly.
Thanks a lot, this is definitely solved!
