Activate "state_color" based on a temperature value
Normally state_color configuration variable for an entity can be turned on or off based on object state. But is there maybe a way to utilize state_color for a sensor? Maybe is there a possibility in frontend to say eg. if temperature sensor raise above 23 degree, then activate state_color to have the icon changed.
I know is possible to define a new eg. template sensor to cover on/off functionality based on temperature value, but maybe can be made more simple.
Hope I explain correctly, as I’m a bit beginner in this.
Thanks for any hint :slight_smile:
