Yesterday I upgraded my Raspberry 3 as suggested. I’ve also upgraded the OS, because the interface suggested these.
Now I have the following versions:
Supervisor: supervisor-2021.01.5
Core: core-2021.1.4
Host: Home Assistant OS 5.10
My Razberry 2 Z-wave-controller GPIO module won’t start after that. Everything worked before the upgrade.
I’ve checked that the configuration in configuration.yaml is still there:
zwave:
usb_path: /dev/ttyAMA0 (that’s the device that is presented under Supervisor/System/Host/Hardware)
The OZW-log shows the following:
2021-01-18 20:31:37.772 Always, OpenZwave Version 1.4.3469 Starting Up
2021-01-18 20:31:45.640 Info, Setting Up Provided Network Key for Secure Communications
2021-01-18 20:31:45.640 Warning, Failed - Network Key Not Set
2021-01-18 20:31:45.640 Info, mgr, Added driver for controller /dev/ttyAMA0
2021-01-18 20:31:45.641 Info, Opening controller /dev/ttyAMA0
2021-01-18 20:31:45.641 Info, Trying to open serial port /dev/ttyAMA0 (attempt 1)
2021-01-18 20:31:45.641 Info, Serial port /dev/ttyAMA0 opened (attempt 1)
2021-01-18 20:31:45.642 Detail, contrlr, Queuing (Command) FUNC_ID_ZW_GET_VERSION: 0x01, 0x03, 0x00, 0x15, 0xe9
2021-01-18 20:31:45.642 Detail, contrlr, Queuing (Command) FUNC_ID_ZW_MEMORY_GET_ID: 0x01, 0x03, 0x00, 0x20, 0xdc
2021-01-18 20:31:45.642 Detail, contrlr, Queuing (Command) FUNC_ID_ZW_GET_CONTROLLER_CAPABILITIES: 0x01, 0x03, 0x00, 0x05, 0xf9
2021-01-18 20:31:45.642 Detail, contrlr, Queuing (Command) FUNC_ID_SERIAL_API_GET_CAPABILITIES: 0x01, 0x03, 0x00, 0x07, 0xfb
2021-01-18 20:31:45.642 Detail, contrlr, Queuing (Command) FUNC_ID_ZW_GET_SUC_NODE_ID: 0x01, 0x03, 0x00, 0x56, 0xaa
2021-01-18 20:31:45.642 Info, contrlr, Sending (Command) message (Callback ID=0x00, Expected Reply=0x15) - FUNC_ID_ZW_GET_VERSION: 0x01, 0x03, 0x00, 0x15, 0xe9
2021-01-18 20:31:45.642 Detail, contrlr, Notification: DriverFailed
After that I opened the config.txt and realized that the following line is missing (which was there before I updated hassio): dtoverlay=pi3-miniuart-bt
Added that line again and started HomeAssistant, but still got the same error in the log and Z-wave does not start.
