Activating Scene - Arggg!
I have landscape light that turn on at sunset, working great.
I have a scene called Halloween Lights (purple, orange, etc,) - manually activating works great.
I have an automation that runs, and if its the month of October set scene, if 4th of July set scene, etc.
The trace says it ran, and set the scene, but the scene never gets activate.
Checking again, manually setting the scene works, what am I missing?
Something undoing the scene shortly after, if not at the exact same time? Sort the automations on last run timestamp to see what else ran, and/or check the logbook.
Nothing in the log, nothing else attached to the lights even except for:
  • At Sunset Turn on light
  • 5 minutes after sunset set colors
Manually setting the time this morning to launch morning, same results. Lights are on, manually setting the scene, confirmed. Setting the automation to run at 9:43am, and trace shows it ran, and set sucessfully, but no luck.
You say there’s nothing else attached, but did you do what I said? If everything was the way you think it is, it would have worked :wink: Also, show the automation. are you sure it is turning the scene on, not something else with a similar name?
Is the scene showing info on that it was run?
Post the automation.
