I don´t understand, I have activated the context storage in the settings.js like it is written in the dcoumentation und here:
https://community.home-assistant.io/t/activating-storage-to-local-file-system-is-not-working/464718
* Copyright JS Foundation and other contributors, http://js.foundation
* Licensed under the Apache License, Version 2.0 (the "License");
* you may not use this file except in compliance with the License.
* You may obtain a copy of the License at
* http://www.apache.org/licenses/LICENSE-2.0
* Unless required by applicable law or agreed to in writing, software
* distributed under the License is distributed on an "AS IS" BASIS,
* WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied.
* See the License for the specific language governing permissions and
* limitations under the License.
* PLEASE NOTE! IMPORTANT! READ!
* This is a modified version of the settings file. Some parts of the
* settings are actually controlled by the Home Assistant add-on.
* Parts that are handled by it, are removed from this settings template.
* The following configuration keys are controlled by the add-on and removed.
* - uiPort (port setting in the add-on log)
* - uiHost (no need to manually configure this in the add-on)
* - debugUseColors (disabled, won't work in the add-on)
* - flowFile (fixed to flows.json)
* - credentialSecret (credentials_secret in the add-on configuration)
* - userDir (is set fixed to `/config/node-red`)
* - nodesDir (is set fixed to `/config/node-red/nodes`)
* - adminAuth (known as users in the add-on configuration)
* - https (ssl settings in the add-on configuration)
* - logging.console.level (log_level in the add-on configuration)
* - httpNodeAuth (http_node settings in the add-on configuration)
* - httpStaticAuth (http_static settings in the add-on configuration)
* - httpNodeRoot (set fixed to `/endpoint` )
* If you like to change those settings, some are available via the add-on
* settings/option in the Supervisor panel in Home Assistant.
module.exports = {
// Retry time in milliseconds for MQTT connections
mqttReconnectTime: 15000,
// Retry time in milliseconds for Serial port connections
serialReconnectTime: 15000,
// Retry time in milliseconds for TCP socket connections
//socketReconnectTime: 10000,
// Timeout in milliseconds for TCP server socket connections
// defaults to no timeout
//socketTimeout: 120000,
// Timeout in milliseconds for HTTP request connections
// defaults to 120 seconds
//httpRequestTimeout: 120000,
// The maximum length, in characters, of any message sent to the debug sidebar tab
debugMaxLength: 1000,
// The maximum number of messages nodes will buffer internally as part of their
// operation. This applies across a range of nodes that operate on message sequences.
// defaults to no limit. A value of 0 also means no limit is applied.
//nodeMaxMessageBufferLength: 0,
// To disable the option for using local files for storing keys and certificates in the TLS configuration
// node, set this to true
//tlsConfigDisableLocalFiles: true,
// By default, the Node-RED UI is available at http://localhost:1880/
// The following property can be used to specify a different root path.
// If set to false, this is disabled.
//httpAdminRoot: '/admin',
// The following property can be used in place of 'httpAdminRoot' and 'httpNodeRoot',
// to apply the same root to both parts.
//httpRoot: '/red',
// When httpAdminRoot is used to move the UI to a different root path, the
// following property can be used to identify a directory of static content
// that should be served at http://localhost:1880/.
//httpStatic: '/home/nol/node-red-static/',
// The maximum size of HTTP request that will be accepted by the runtime api.
// Default: 5mb
//apiMaxLength: '5mb',
// If you installed the optional node-red-dashboard you can set it's path
// relative to httpRoot
//ui: { path: "ui" },
// The following property can be used to disable the editor. The admin API
// is not affected by this option. To disable both the editor and the admin
// API, use either the httpRoot or httpAdminRoot properties
//disableEditor: false,
// The following property can be used to configure cross-origin resource sharing
// in the HTTP nodes.
// See https://github.com/troygoode/node-cors#configuration-options for
// details on its contents. The following is a basic permissive set of options:
//httpNodeCors: {
// origin: "*",
// methods: "GET,PUT,POST,DELETE"
// If you need to set an http proxy please set an environment variable
// called http_proxy (or HTTP_PROXY) outside of Node-RED in the operating system.
// For example - http_proxy=http://myproxy.com:8080
// (Setting it here will have no effect)
// You may also specify no_proxy (or NO_PROXY) to supply a comma separated
// list of domains to not proxy, eg - no_proxy=.acme.co,.acme.co.uk
// The following property can be used to add a custom middleware function
// in front of all http in nodes. This allows custom authentication to be
// applied to all http in nodes, or any other sort of common request processing.
//httpNodeMiddleware: function(req,res,next) {
// // Handle/reject the request, or pass it on to the http in node by calling next();
// // Optionally skip our rawBodyParser by setting this to true;
// //req.skipRawBodyParser = true;
// next();
// The following property can be used to verify websocket connection attempts.
// This allows, for example, the HTTP request headers to be checked to ensure
// they include valid authentication information.
//webSocketNodeVerifyClient: function(info) {
// // 'info' has three properties:
// // - origin : the value in the Origin header
// // - req : the HTTP request
// // - secure : true if req.connection.authorized or req.connection.encrypted is set
// // The function should return true if the connection should be accepted, false otherwise.
// // Alternatively, if this function is defined to accept a second argument, callback,
// // it can be used to verify the client asynchronously.
// // The callback takes three arguments:
// // - result : boolean, whether to accept the connection or not
// // - code : if result is false, the HTTP error status to return
// // - reason: if result is false, the HTTP reason string to return
// Anything in this hash is globally available to all functions.
// It is accessed as context.global.
// eg:
// functionGlobalContext: { os:require('os') }
// can be accessed in a function block as:
// context.global.os
// os:require('os'),
// jfive:require("johnny-five"),
// j5board:require("johnny-five").Board({repl:false})
// The following property can be used to order the categories in the editor
// palette. If a node's category is not in the list, the category will get
// added to the end of the palette.
// If not set, the following default order is used:
paletteCategories: [
"home_assistant",
"home_assistant entities",
"subflows",
"common",
"function",
"network",
"sequence",
"parser",
"storage",
// Configure the logging output
logging: {
// Only console logging is currently supported
console: {
// Whether or not to include metric events in the log output
metrics: false,
// Whether or not to include audit events in the log output
audit: false,
// Customising the editor
editorTheme: {
projects: {
// To enable the Projects feature, set this value to true
enabled: false,
// Context Storage
// The following property can be used to enable context storage. The configuration
// provided here will enable file-based context that flushes to disk every 30 seconds.
// Refer to the documentation for further options: https://nodered.org/docs/api/context/
contextStorage: {
storeInFile: { module: "localfilesystem"},
memoryOnly: { module: "memory"},
default: "memoryOnly"
contextStorage: {
storeInFile: { module: “localfilesystem”},
memoryOnly: { module: “memory”},
default: “memoryOnly”
I have just this one settings.js file under /config/_node-red/
After NR-Restart I don´t see anything in the logs about context storage, I don´t get the context folder and of course I don´t have the hamburger in the change node.
What am I doing wrong?
