Active BLE Proxy - how to add device from HACS integration?
Hi all,
I’ve been trying to get the Basestations for my Valve Index working with the Basestation integration found here: GitHub - jariz/homeassistant-basestation: Read and manage power states for your Valve Index® Base Stations in Home Assistant.
Unfortunately my Home Assistant instance is too far away so I’ve flashed an ESP32 to be a BLE proxy.
Unfortunately I’m kind of stuck now because the guides that show what to do seem to expect you to be able to add it through the UI and that it will be auto-discovered by HA which isnt the case here. The base stations are added via configuration.yaml.
Does anyone know how I could get HA to start communicating with the Basestations via Proxy?
