Active Zones
I moved from HomeSeer to HA and do not regret :slight_smile: for most part
In HomeSeer I used a Plugin called BLRadar This plugins helped me to define occupancy/active zone functions based on motion sensors.
In other words I want to have an active zone entity based on the fact a motion sensor detected motion within a definable time range.
What is the best/easiest way to do this?
Probably easiest to create a template binary_sensor per room and then use the delay off property to only turn it off after the motion sensor was off for x amount of time
