This post is likely only relevant to OZ. Is there an ad blocker or similar that will still allow me to use the SBS service. SBS has some real boffins who block any access whilst using any ad blocker I’ve tried. I’m wondering if i need to set up and ad blocker for all other traffic other than SBS?
Pat
Most if not all as blockers will allow you to set custom rules so as to allow specific domains to bypass the ad blocking rules.
Similarly you could run the ad blocker while running SBS and check what is being blocked and selectively unblock certain domains etc to find a happy medium.
