I’m trying to switch from Alexa to Home assistant (or OpenHAB). I tried installing ada and Almond and now I can get ada to respond. I’v said a million times “Hey ada” and it never works. I am running a pi 4, With homeassistant, and a USB mic and USB speaker. and it still is not working. If anyone can help it is very appreciated. Thank you!
If you’re still working on this, try “Hey Pico”. (‘Peeko’) Check the video that’s in the blog post linked at the bottom of the “Info” tab of the Ada add-on.
