Just wondering if anyone has got this working in ESPHome by directly communicating with the boards PCA9685 (it’s integrated with ESPHome already) to control the two onboard TB6612FNG’s?
Couple of reasons for using this is that instead of interfacing 4 TB6612’s to my central ESP32 uses up 3 pins per TB6612 (12) and with this i2c board it only uses two pins (SCL + SDA) for all 8 motors with room for expansion.
There is no DC + Stepper component so I thought I could do it this way. It discovers my two boards (0x60 and 0x61 with all call of 0x70) and they both work via IDE examples but cannot get them to work via Home Assistant. It uses the default address of 0x60 for this board even though its connection is with a PCA9685 which is normally 0x40 but that’s fine and have addressed it as 0x60 but could be why it’s not working as expected. I’m hopefully using it as intended for 4 motors, not 2 steppers by the way.
I’ve read that the PCA9685 is fine for using 100% duty to use as a GPIO pin for setting direction and then PWM on the normal pin.
The end goal is to use the 8 outputs (4 DC motors) on my 12v peristaltic pumps. Forward only, PWM to slow the output.
Schematic and details on the board are below along also my ESPHome .yaml for it. As I mentioned I matched the PCA9685 to the two TB6612 h-bridge’s in the yaml but no motor output on any of the motor outs?
Board general info: https://learn.adafruit.com/adafruit-stepper-dc-motor-featherwing/downloads
Schematic: https://cdn-learn.adafruit.com/assets/assets/000/034/460/original/feather_schem.png?1469829943
My ESPHome config with output set as switch @ 100% PWM for enable/PWM pin for testing:
esphome:
friendly_name: Feather
esp32:
board: um_feathers3
framework:
type: arduino
external_components:
- source:
type: git
url: https://github.com/esphome/esphome.git
ref: 2022.12.8
components: [ pca9685 ]
# Enable logging
logger:
level: VERY_VERBOSE
# Enable Home Assistant API
api:
ota:
wifi:
ssid: !secret wifi_ssid
ap:
ssid: "Feather Fallback Hotspot"
password: "5JEmaTMl9JkT"
captive_portal:
i2c:
scan: True
sda: 8
scl: 9
# Example configuration entry
pca9685:
- id: pca9685_hub1
address: 0x60
frequency: 50
- id: pca9685_hub2
address: 0x61
frequency: 50
# Individual outputs
output:
- platform: pca9685
pca9685_id: 'pca9685_hub1'
channel: 2
- platform: pca9685
channel: 4
- platform: pca9685
channel: 3
- platform: pca9685
channel: 7
- platform: pca9685
channel: 5
- platform: pca9685
channel: 6
- platform: pca9685
channel: 8
- platform: pca9685
channel: 10
- platform: pca9685
channel: 9
- platform: pca9685
channel: 13
- platform: pca9685
channel: 11
- platform: pca9685
channel: 12
# Motor A
switch:
icon: "mdi:chemical-weapon"
turn_on_action:
# Clockwise direction:
- output.set_level:
level: 100%
- output.set_level:
level: 0%
- delay: 500ms
- output.set_level:
level: 100%
- switch.template.publish:
state: ON
turn_off_action:
- output.set_level:
level: 0%
- output.set_level:
level: 0%
- output.set_level:
level: 0%
state: OFF
# Motor B
turn_on_action:
- output.set_level:
level: 100%
- output.set_level:
level: 0%
- delay: 500ms
- output.set_level:
level: 100%
state: ON
turn_off_action:
- output.set_level:
level: 0%
- output.set_level:
level: 0%
- output.set_level:
level: 0%
state: OFF
# Motor C
turn_on_action:
- output.set_level:
level: 100%
- output.set_level:
level: 0%
- delay: 500ms
- output.set_level:
level: 100%
state: ON
turn_off_action:
- output.set_level:
level: 0%
- output.set_level:
level: 0%
- output.set_level:
level: 0%
state: OFF
# Motor d
turn_on_action:
- output.set_level:
level: 100%
- output.set_level:
level: 0%
- delay: 500ms
- output.set_level:
level: 100%
state: ON
turn_off_action:
- output.set_level:
level: 0%
- output.set_level:
level: 0%
- output.set_level:
level: 0%
state: OFF
Log outputs no errors but can post up if needed.
