Adapting a docker image to Home Assistant add-on
Hi All
I am trying to convert a docker image (that has Apache and Perl) to work as a HASS.io add-on, and every time I try to install, it flashes red, and it doesn’t display any error. Is there any way I can debug this? What am I doing wrong
Here is the dockerfile:
FROM hassioaddons/debian-base-armhf:0.2.2
RUN \
    DEBIAN_FRONTEND=noninteractive && \
    apt-get update && \
    apt-get install -y \
        build-essential \
        apt-utils \
        ssl-cert \
        apache2 \
        apache2-utils \
        apache2-dev \
        libapache2-mod-perl2 \
        libapache2-mod-perl2-dev \
        libcgi-pm-perl \
        liblocal-lib-perl \
        cpanminus \
        libexpat1-dev \
        libssl-dev \
        mysql-client \
        libmysqlclient-dev \
        libapreq2-dev \
        zip && \
    cpanm DBD::mysql && \
    a2enmod cgid && \
    a2enmod rewrite && \
    a2dissite 000-default && \
    apt-get update -y && \
    apt-get upgrade -y && \
    apt-get -y clean
#COPY localhost.conf /etc/apache2/sites-enabled/localhost.conf
#VOLUME ["/var/www/html"]
#EXPOSE 80
COPY rootfs /
# Build arugments
ARG BUILD_DATE
ARG BUILD_REF
ARG BUILD_VERSION
# Labels
LABEL \
    io.hass.name="batam" \
    io.hass.description="batam" \
    io.hass.arch="${BUILD_ARCH}" \
    io.hass.type="addon" \
    io.hass.version=${BUILD_VERSION} \
    maintainer="Thomas Watkins" \
    org.label-schema.description="Perl Experiment" \
    org.label-schema.build-date=${BUILD_DATE} \
    org.label-schema.name="batam" \
    org.label-schema.schema-version="1.0" \
    org.label-schema.vcs-ref=${BUILD_REF} \
build.json:
    "build_from": {
        "armhf": "hassioaddons/debian-base-armhf:0.2.2"
    "args": {}
config.json:
  "name": "Batam",
  "version": "0.01.00",
  "slug": "Batam",
  "description": "Perl Test",
  "startup": "services",
  "boot": "auto",
  "hassio_api": false,
  "homeassistant_api": false,
  "host_network": true,
  "webui": "http://[HOST]:[PORT:80]",
  "auto_uart":true,
  "map": [
    "config:rw"
  "options": {
    "httpport": 8080,
  "schema": {
    "httpport": "port",
  "ports": {
    "8080/tcp": 8080,
You may have a look at the system log: http://hassio.local:8123/hassio/system
