šŸ’Ø Adaptive fan speed control based on temperature and speed range
Exactly! Iā€™m thinking like you set the desired temperature on your AC unit with your remote. Sometimes you want a bit warmer and sometimes a bit cooler.
The min/max value would be set via the offset. Those youā€™d just have to set once as the ā€œtemperature curveā€ would then move up and down based on the set temperature.
Sir_Goodenough has a working input number in his BP if that would help
https://community.home-assistant.io/t/auto-fan-temp-control-for-3-speed-fan-using-ha-fan-or-mqtt-integration/326419
Would you be able to add to the blueprint an option to invert the blocking entity so that it would work with an entity that is off. My use case is a whole house fan that I want to run, but only when the window is open, which in this case it goes from an off state to on state.
Also it would be nice to have a separate enabling entity you can chose. Idea being I could install a remote switch that starts of the automation, otherwise the automation is disabled.
If youā€™re not aware a Blueprint can be converted to a regular Automation, then you could make all your customisations.
Hi @adamalli7, sorry for my late reply and thanks for your interest and ideas. Regarding your request to add an option to invert the blocking entity, I think the cost for implementing this in terms of the logic needed and the added complexity, proabably means I wonā€™t add this feature. A much easier way would be to create your own template sensor that inverts the state of your entity. Hereā€™s an example of how to to that:
  1. Open your Home Assistant configuration file: This is usually located at /config/configuration.yaml.
  2. Add the template sensor configuration: In your configuration.yaml file, add the following lines to define your template sensor. Replace sensor.your_entity with the actual entity ID you want to invert.
template:
  - sensor:
      - name: "Inverted Entity State"
        state: >
          {% if is_state('sensor.your_entity', 'on') %}
            off
          {% else %}
            on
          {% endif %}
        availability: >
          {{ states('sensor.your_entity') not in ['unknown', 'unavailable'] }}
Hope this helps!
@cappadanna I havnā€™t forgotten about you! I just need to find the time to implement it :joy:
I just changed the blueprint to do what I needed it to do. Simple as changing the entity value from ā€œonā€ to ā€œoffā€
No worries, I know just how it is :joy:
Hey,
I really like your blueprint the only thing that is missing is a maximum percentage change. I got some wild jumps on my air conditioning fan. :joy:
Could you implant this value as well?
Thanks!
Haha interesting! Was that caused by a large jump in temperature though? Whatā€™s your thoughts on what should happen in this case? Eg: should the blueprint set the fan to the maximum allowed step change in fan speed and then continue to step it up until it eventually reached the required fan speed for the current temperature?
@Creepe95 ok Iā€™ve added a maximum percentage change slider. Give it a go and let me know how it goes :slight_smile:
Update the blueprint by re-importing it. It is backwards compatible, so your old settings will be preseved if you have any automations that are already using this blueprint.
Notes on this change:
To ensure the set_fan_speed value never increases or decreases by more than a desired threshold, you can set a max_change which is a threshold value set for the difference betwen the current fan_speed and the calculated set_fan_speed. If the difference exceeds max_change, the set_fan_speed will be adjusted to fan_speed + max_change (for the positive direction) or fan_speed - max_change (for the negative direction) as necessary.
IMPORTANT!
Because the automation is triggered only when the temperature sensor changes or when the fan is turned on, if you have set a small max_change and the time between temperature changes is large, the time it takes for the fan to get the set_fan_speed could be large.
ā€“edit-- nvm, I think the script below works.
Awesome blueprint!
Iā€™ve tried to add the option to select another temperature sensor for the off_temp variable, which also influences the min_temp with an additional selector. But the fan speed doesnā€™t seem to change. Do you have any tips/remarks? Cheers.
blueprint:
  name: Auto fan speed sensor
  description: "Temperature based Auto fan control.\n\n Fan Speed will be set when
    initially turned on by relating the ambient temperature to an equivalent speed
    setting. \nA time delay and a minimum percentage change is used to eliminate frequent
    speed changes.\n At the minimum temperature setting the fan will turn off. \n
    When the temperature rises above this minimum temperature setting, the fan will
    automatically turn back on."
  domain: automation
  input:
    temp_sensor:
      name: "\U0001F321 Temperature Sensor"
      description: Enter your temperature sensor. Make sure the temperature sensor
        is in the units (Ā°C or Ā°F) you want to use for the settings below. If your
        temp sensor is in Ā°C but you want to use the Ā°F settings, you will need to
        create a template sensor to convert the sensor into the correct units.
      default: []
      selector:
        entity:
          domain:
          - sensor
          device_class:
          - temperature
          multiple: false
    off_temp_sensor:
      name: "\U0001F321 Off Temperature Sensor"
      description: "Enter a different temperature sensor to determine when the fan should turn off. This sensor will also be used to determine the minimum temperature setting."
      default: []
      selector:
        entity:
          domain:
          - sensor
          device_class:
          - temperature
          multiple: false
    temp_adjustment:
      name: "\U0001F321 Temperature Adjustment"
      description: "Adjust the temperature added to the off temperature for setting the minimum fan speed temperature."
      default: 2
      selector:
        number:
          min: 0.0
          max: 10.0
          step: 0.5
          mode: slider
          unit_of_measurement: 'Ā°C'
    fan_switch:
      description: The fan you wish to speed control.
      selector:
        entity:
          domain:
          - fan
          multiple: false
    min_fan_speed:
      name: "\U0001F4A8 Minimum Fan Speed"
      description: Set the minimum percentage speed when your fan is still on.
      default: 16
      selector:
        number:
          min: 1.0
          max: 100.0
          mode: slider
          step: 1.0
          unit_of_measurement: '%'
    max_fan_speed:
      name: "\U0001F4A8 Maximum Fan Speed"
      description: Set the maximum percentage speed for your fan.
      default: 100
      selector:
        number:
          min: 1.0
          max: 100.0
          mode: slider
          step: 1.0
    max_temp:
      name: "\U0001F4C8 Maximum Temperature"
      description: What temperature would you like the fan to run at max fan speed.
      default: 40
      selector:
        number:
          min: 10.0
          max: 120.0
          step: 1.0
          mode: slider
    auto_turn_on_enabled:
      name: āœ… Enable auto fan on
      description: "Let the fan automatically turn back on if the temperature returns to a value above the temperature that the fan switches off."
      default: true
      selector:
        boolean: {}
    change_time:
      name: ā±ļø Change frequency delay
      description: How long to delay between potential speed adjustments.
      default: 30
      selector:
        number:
          min: 1.0
          max: 120.0
          unit_of_measurement: minutes
          step: 1.0
          mode: slider
    change_threshold:
      name: Minimum percentage change
      description: The minimum percentage change (between current fan speed and set
        fan speed)
      default: 1
      selector:
        number:
          min: 1.0
          max: 100.0
          mode: slider
          step: 1.0
    max_change:
      name: Maximum percentage change
      description: The maximum percentage change (between current fan speed and set
        fan speed)
      default: 50
      selector:
        number:
          min: 1.0
          max: 100.0
          mode: slider
          step: 1.0
    blocker_entity:
      name: (OPTIONAL) Blocking entity
      description: If this entity's state is on, it will prevent the automation from
        running. E.g. sleep mode or away mode.
      default:
      selector:
        entity:
          multiple: false
  source_url: https://community.home-assistant.io/t/adaptive-fan-speed-control-based-on-temperature-and-speed-range/678152
variables:
  temp_sensor: !input temp_sensor
  off_temp_sensor: !input off_temp_sensor
  temp_adjustment: !input temp_adjustment
  fan_switch: !input fan_switch
  auto_turn_on_enabled: !input auto_turn_on_enabled
  min_fan_speed: !input min_fan_speed
  max_fan_speed: !input max_fan_speed
  max_temp: !input max_temp
  current_temp: '{{ states(temp_sensor) | float(0)}}'
  off_temp: '{{ states(off_temp_sensor) | float(0)}}'
  min_temp: '{{ off_temp + temp_adjustment }}'
  change_time: !input change_time
  max_change: !input max_change
  change_threshold: !input change_threshold
  blocker_entity: !input blocker_entity
  fan_speed: '{{ state_attr(fan_switch,''percentage'') | float(0)}}'
  temp_range: '{{ max_temp | float(0) - min_temp | float(0)}}'
  fan_range: '{{ max_fan_speed | float(0) - min_fan_speed | float(0)}}'
  slope: '{{ fan_range | float(0)/temp_range | float(0)}}'
  initial_set_fan_speed: '{{ [[slope|float(0) * (current_temp|float(0) - min_temp|float(0))
    + min_fan_speed|float(0),  min_fan_speed] | max, max_fan_speed] | min}}'
  adjusted_set_fan_speed: "{% set diff = initial_set_fan_speed - fan_speed %} {% if
    diff > max_change|float(0) %}\n  {{ fan_speed + max_change|float(0) }}\n{% elif
    diff < -max_change|float(0) %}\n  {{ fan_speed - max_change|float(0) }}\n{% else
    %}\n  {{ initial_set_fan_speed }}\n{% endif %}\n"
  set_fan_speed: '{{ adjusted_set_fan_speed }}'
  speed_diff: '{{(fan_speed - set_fan_speed)|abs}}'
- platform: state
  entity_id:
  - !input fan_switch
  to: 'on'
- platform: state
  entity_id:
  - !input temp_sensor
condition:
- condition: template
  alias: Check for blocker entity
  value_template: '{{ (blocker_entity == none) or (states(blocker_entity) == ''off'')}}'
- choose:
  - conditions:
    - condition: trigger
      alias: Only run if fan was switched on
      alias: Is the percentage change great enough?
      value_template: '{{ speed_diff | float(0) > change_threshold | float(0) }}'
    sequence:
    - service: homeassistant.turn_on
        percentage: '{{set_fan_speed}}'
        entity_id: '{{fan_switch}}'
    - delay:
        minutes: !input change_time
  - conditions:
      value_template: '{{states(fan_switch) == ''on''}}'
      alias: Make sure the fan is already on (ignore if it's been switched off)
      alias: Is the temperature above the off temp?
      value_template: '{{ current_temp | float(0) > off_temp | float(0) }}'
    sequence:
    - delay:
  - conditions:
    - condition: not
      alias: Make sure the fan hasn't just been turned on
      conditions:
      alias: Check if the temperature is below off_temp
      value_template: '{{ states(off_temp_sensor) | float(0) < (off_temp | float(0)) }}'
    sequence:
    - service: homeassistant.turn_off
  - conditions:
    - '{{ auto_turn_on_enabled }}'
      value_template: '{{states(fan_switch) == ''off''}}'
      alias: Is the fan currently off?
    sequence:
    - delay:
mode: single
Is there a change to Integration the climate entity directly?
Currently i need to create a extra Fan Sensor for that
