Adaptive Fan Speed Control
Automatically controls fan speed based on one or more sensors — temperature,
humidity, or air quality — and/or a thermostat's deviation from setpoint.
Each sensor is evaluated independently and the fan always serves the most
urgent condition, no averaging or dilution.
Note: I don't have an AQ sensor (if someone can test and report?) but in theory everything should work. I faked one but without an actual test of each type hard to say for sure.
:heart: Credits
This blueprint is a fork of lennon101's excellent Adaptive fan speed control based on temperature and speed range, which was itself based on MickW69's Multi-speed Fan Control Based on Temperature.
All credit for the original concept and groundwork goes to them. I myself used lennon101's version for a long while until I needed extra features. This fork is the result of that and extends the original with multi-sensor support, humidity and air quality modes, thermostat mode, partial sensor degradation, notification throttling, and a handful of quality-of-life improvements around testing and configuration.
:raised_hand_with_fingers_splayed: Usage
  1. Import the Blueprint
    Import Blueprint
  2. Create an Automation from the imported Blueprint
    Open Blueprints
  3. Add your sensors — one or more temperature, humidity, or air quality
    sensors, and/or a single-setpoint thermostat
  4. Fill in the threshold sliders for whichever sensor types you're using —
    the rest are ignored automatically
:sparkles: Features
  • Multiple sensors — configure as many sensors and/or thermostats as you
    like; whichever computes the highest fan speed wins. The fan only turns off
    once every configured sensor agrees it's satisfied
  • Auto-detected sensor modes — Temperature, Humidity, Air Quality, and
    Thermostat modes are detected automatically from each entity's device_class;
    each mode has its own dedicated threshold sliders
  • Humidity direction — High Mode ramps up as humidity rises (e.g. a
    bathroom exhaust fan); Low Mode ramps up as humidity falls (e.g. circulating
    dry air)
  • Air quality cooldown bypass — any active air quality sensor skips the
    cooldown delay entirely so it can respond on every check; air quality events
    are more time-sensitive than comfort-based ones
  • Thermostat support — deviation from setpoint drives fan speed instead of
    absolute value; direction flips automatically with HVAC mode (Cool vs. Heat)
  • Partial sensor degradation — if one sensor goes offline, the automation
    keeps running off whichever sensors are still healthy rather than freezing
    entirely; it only freezes if every configured sensor is down simultaneously
  • Unavailable sensor notifications — optional companion app notification
    when a sensor goes down, listing which ones; throttled to once per outage
    plus a one-time "recovered" notification with an optional tracking helper
  • Configurable update frequency — polls every 5, 10, 15, 30, or 60 seconds,
    independent of how often your sensor actually reports updates
  • Cooldown delay — configurable delay between speed adjustments to prevent
    jittery, frequent changes; can be disabled entirely via a toggle for easier
    testing
  • Maximum percentage change — caps how much the fan speed can change per
    adjustment for smoother ramps
  • Auto turn-on — optionally turns the fan back on automatically once a
    sensor crosses back above its off threshold
  • Blocker entity — disable the automation entirely via a helper (e.g. sleep
    mode, away mode)
  • Custom trigger override — add your own trigger(s) to supplement the
    polling interval, e.g. react on every native sensor state change
:gear: How sensor modes work
Mode is auto-detected per entity from its device_class attribute — you don't
configure this separately. All mode inputs are always visible (blueprints
can't conditionally hide inputs), but only the ones matching your sensor types
are actually used.
Sensor type Mode triggered Threshold inputs used
climate.* entity Thermostat Mode Deviation Amount, Deviation Off
device_class: humidity Humidity Mode Min/Max/Off Humidity + Direction
device_class: aqi / carbon_dioxide / pm25 / etc. Air Quality Mode Min/Max/Off Air Quality
Anything else (or no device_class) Temperature Mode (fallback) Min/Max/Off Temperature
Note: Temperature Mode is the fallback for anything unrecognized — including
sensors with no device_class set at all. If you're using a custom ESPHome
sensor for humidity or air quality, check in Developer Tools → States that its
device_class attribute is set correctly, otherwise it will silently fall into
Temperature Mode and use the wrong sliders.
Multiple sensors — max-wins combination
When more than one sensor is configured, each computes its own target fan speed
independently. The highest result wins — the fan always serves the most urgent
condition, never an average of all of them. A sensor that's satisfied (below its
own off threshold) contributes 0 to the comparison, so it can never suppress a
more urgent signal from a different sensor.
Example: AQ sensor wants 75% (CO2 climbing), thermostat wants 0% (room is
comfortable) → fan runs at 75%. The thermostat's 0 loses the comparison; it
doesn't dilute or cap the AQ result.
The reverse also holds: if temperature is critical and AQ is mild, temperature
still wins. No sensor type has hardcoded priority — whichever is most demanding
at that moment drives the fan.
:wrench: Configuration
Input Description
Sensors or Thermostat(s) One or more sensor.* or climate.* entities — add as many as you need
Fan The fan entity to control
Min / Max Fan Speed Speed range the fan operates in
Min / Max / Off Temperature Temperature Mode thresholds (absolute degrees)
Min / Max / Off Humidity Humidity Mode thresholds (%)
Humidity Direction High (more fan as humidity rises) or Low (more fan as humidity falls)
Min / Max / Off Air Quality Air Quality Mode thresholds (ppm, µg/m³, index, etc.)
Deviation Amount Thermostat Mode — deviation from setpoint that maps to max fan speed
Deviation Off Thermostat Mode — deviation below which the fan turns off
Enable auto fan on Whether the fan turns back on automatically when a sensor crosses above its off threshold
Update Check Frequency How often to re-evaluate sensors (5–60 seconds)
Change frequency delay Cooldown between speed adjustments (30–1200 seconds)
Enable Change Frequency Delay Toggle the cooldown on/off — turn off while testing
Minimum percentage change Smallest speed change worth making
Maximum percentage change Largest speed change allowed per adjustment
Blocking entity (optional) If this entity is "on", the automation won't run (I use a "quite time" helper and an automation to reset after time limit)
Custom Trigger Override (optional) Add your own trigger(s) to supplement the polling interval (untested but in theory should work)
Notify Device (optional) Companion app device to notify if a sensor goes unavailable
Notify State Helper (optional) An input_boolean you create — throttles unavailable notifications to once per outage and enables a recovery notification
:bulb: Tips, gotchas, and known limitations
  • Air quality defaults are intentionally aggressive — the Off/Min/Max Air
    Quality defaults use a tighter range than temperature so the fan ramps to full
    speed faster. Tune these to your actual sensor's scale (CO2 ppm, AQI index,
    µg/m³, etc. all use different ranges)
  • Disable the cooldown while testing — especially useful when manually
    nudging a thermostat setpoint to watch the fan respond; with the cooldown
    enabled the automation sleeps through several check cycles at once, which makes
    speed changes appear to skip ahead rather than step through the ramp
  • Thermostat mode: single-setpoint only — dual-setpoint thermostats (Heat/Cool
    or Auto mode with separate high/low targets) aren't supported; the missing
    temperature attribute is treated like an unavailable sensor
  • All mode threshold inputs are always visible in the configuration form —
    blueprints can't conditionally hide inputs based on which sensor types you've
    added, so the unused ones just get ignored
  • Same-type sensors share thresholds — two humidity sensors in the list share
    one set of humidity sliders, not independently configurable ones
  • Mode detection requires device_class to be set on the entity — worth
    checking in Developer Tools → States before assuming it's working
:hammer: Changelog
  • 2026-06-24: Initial release
:hot_beverage: Buy me a coffee
Not able to install.
Try now reotto. Removed the version tag causing problems.
:pushpin: Update — v1.1.0
Several new features have been added since the original post. Use the import button below to get the latest version:
Import Blueprint
What’s new in v1.1.0:
  • Ambient Reference Sensor — an optional outdoor temperature sensor or home-average helper that stops the fan from chasing an unachievable target. If it’s 26°C outside and the fan is pulling in fresh air, it stops trying to push the room below 26°C and turns off once it reaches ambient instead. Works for humidity too.
  • Blocking Entity Action — the blocking entity input now has a toggle: Pause (fan coasts at its current speed, no adjustments) or Shut Off (fan turns off immediately when the blocker activates). For instant shutoff without waiting for the next poll cycle, add a state trigger on the blocker entity to the Custom Trigger Override input.
  • Instant blocker response — the cooldown delay now uses wait_template instead of delay, so it exits immediately if the blocker activates mid-wait rather than sleeping through the rest of the cooldown period.
Full changelog and documentation on GitHub.
