Adaptive Lighting custom integration not transitioning properly
I’ve been having issues with my install of adaptive lighting. If I reload the integration in the morning, the lights will be the proper colour and transition to the evening but then they don’t transition back to daylight colors in the morning. I have previously had it setup where it was working flawlessly so I’m not sure what changed.
I’ve tried the following but nothing so far has resolved the issue:
  1. Delete integration and recreate all instances of the integration
  2. Installed a fresh instance of home assistant and setup adaptive lighting
  3. Installed home assistant on dedicated machine running Home Assistant OS
Here is information about my system configuration:
Adaptive Lighting Version: 1.19.1
Home assistant OS running on dedicated mini pc
Home Assistant 2023.10.5
Supervisor 2023.10.1
Operating System 11.0
Frontend 20231005.0 - latest
Hardware integrations are a combination of Tuya Cloud and IKEA.
The fact that I’m having the same issue with a fresh install suggest to me it might be a hardware issue but that doesn’t make much sense to me either. If anyone has managed to resolve a similar issue, your guidance would be appreciated.
