🌅 Adaptive Lighting Scheduler
GitHub Code Release
This blueprint calculates optimal brightness and color temperature values throughout the day and stores them in input_number helpers for use by other automations and blueprints.
:sparkles: Key Features
  • Flexible Scheduling: Choose between per-day schedules or simple workday/non-workday mode with automatic holiday detection
  • Sun Tracking: Optional sunrise/sunset awareness for natural transitions
  • Smooth Ramping: Gradual transitions between day phases (wake, morning, evening, sleep, night)
  • Helper Output: Stores values in input_number entities for use by switches, dashboards, and other automations
  • Direct Light Control: Optionally control lights directly through this blueprint. Works standalone without button automations, or alongside them for centralized adaptive scheduling
  • Auto-Adjust: Automatically update selected lights when schedule changes (only affects lights that are ON)
  • Multiple Zones: Create multiple instances with different helper pairs for different lighting zones
:clipboard: Requirements
  • Home Assistant: Version 2024.10.0 or later
  • Sun Integration: sun.sun entity for sunrise/sunset tracking
  • Workday Integration: Optional, only needed for Workday/Non-Workday mode with automatic holiday detection
Works Great With:
This blueprint pairs perfectly with my switch blueprints that support adaptive lighting mode:
Simply set the Light Adjustment Mode to “Adaptive” in those blueprints and point them to the helpers updated by this scheduler!
Thanks for sharing this. I was looking for a lightweight alternative to the basnijholt/adaptive-lighting integration. Seems to be working great on my bathroom lamp so far!
Yeah, which is why I made it exactly. I had used the Adaptive Lighting Custom Component in the past but it did too much for my needs so I was using Light Schedules for a while which had static times for when to switch the Brightness and Color Temperature.
:warning: New Update Available (2025.12.2)
What’s New:
  • Direct Light Control: Optionally control lights directly from this blueprint - no button automations needed!
  • Auto-Adjust: Automatically update selected lights when the schedule changes (only affects lights that are ON)
  • Flexible Targeting: Select individual lights, entire devices, or whole areas to control
  • Centralized Control: Use with or without button automations - handle adaptive scheduling in one place instead of enabling it in each button blueprint
  • Comprehensive Documentation: All input fields now have clear required/optional tags and detailed descriptions
Two Ways to Use:
  1. Standalone Mode: Perfect if you don’t use button automations - just select your lights and enable auto-adjust!
  2. With Button Automations: Already using the button blueprints? You can now centralize your adaptive scheduling here instead of configuring auto-adjust in each button
Upgrade Instructions: Please re-import the blueprint. Your existing helper-only configurations will continue to work perfectly - the new Direct Light Control section is completely optional and defaults to disabled for backwards compatibility.
:warning: New Update Available (2026.01.1)
Add Workday/Non-Workday schedule mode and documentation improvements
What’s New:
  • Workday/Non-Workday schedule mode with automatic holiday detection
  • Choose between per-day schedules or simple workday/non-workday split
  • Workday Settings input group for configuring workday sensor integration
  • Time configuration groups for Workdays and Non-Workdays
  • GitHub Repository, Blueprint Code, and Version badges in description
  • Version History input group with collapsible changelog
  • Helper Configuration collapsible input group
  • Section icons and improved formatting (:sparkles:, :gear:, :date:, :bulb:, :clipboard:)
  • Simply re-import the blueprint and reload Automations
  • All changes are backward compatible
  • To use Workday mode, install the Workday integration and configure your workday sensor
:warning: New Update Available (2026.01.2)
Fix adaptive lighting “Already running” errors
What’s Fixed:
  • Automation triggering twice simultaneously causing “Already running” errors
  • Removed unnecessary sun.sun state trigger - the entity’s elevation and azimuth attributes change continuously throughout the day, causing race conditions with the time_pattern trigger
  • Added mode: restart to handle edge cases of overlapping triggers (e.g., HA restart occurring exactly on a 5-minute mark)
Is there a way for this blueprint to not auto adjust lights if I manually adjust them? For instance at night I have it set to 1% but if I adjust them to 100% can they stay at that value for x amount of time?
Also, if I have a light that was 100% during the day but then off for some time before being turned on again in the middle of the night I would want it to turn on at 1% (not 100% and then wait the up to 5 minutes for the time pattern to trigger it)
I need to research if it is possible to achieve your first question without Custom Components.
For your second question, you should send the Dynamic Brightness and Dynamic Colour with the turn_on event. Not use a raw turn_on. The blueprint checks if a light is on and sends the updates only when it is on. So when it is off and you send a raw turn_on signal, it will use the last state and not use the blueprint values at all.
There are examples on how to use it for turn_on in the blueprint, even with scripts and buttons you can integrate into your dashboard so you never turn it on without also sending the data in the helpers.
:warning: New Update Available (2026.06.1)
Split auto-adjust into separate brightness and color temperature toggles
What's New:
  • Auto-adjust brightness and color temperature can now be enabled independently
  • Useful when you want to lock brightness while letting color temperature follow the schedule, or vice versa
  • Re-save existing automation instances to activate the new toggles (both default to off)
  • Reload the automation after saving
:warning: New Update Available (2026.10.1)
Add change-only and pause options to the Adaptive Lighting Scheduler
What’s Fixed:
  • A light that fails to respond no longer stops the remaining lights from being updated.
What’s New:
  • “Only Apply When The Value Changed”: lights only get a command when the brightness or color temperature actually changed since the previous step. Off by default.
  • “Pause Between Lights”: optional delay in milliseconds after each light that was sent a command. Default 0.
  • Update the blueprint and reload your automations. The new options are off by default.
  • If you enable “Only Apply When The Value Changed”, a light turned on while the value is steady keeps its own value until the next change.
:warning: New Update Available (2026.11.1)
Show the information sections of the Adaptive Lighting Scheduler again
What’s Fixed:
  • Version History, Helper Configuration, Dashboard Scripts and Dashboard Lovelace are visible again in the automation editor. Home Assistant 2026.11 hides blueprint sections without inputs.
  • Update the blueprint and reload your automations. Existing automations need no changes.
