I’m running HA on a rpi4. For awhile now I have been trying to get away from a weather integration and just get an outside sensor. I need better current temp and humidity readings then a weather forecast for my automations. Before buying everything I would like to see if this setup is going to work. From what I can tell AcuRite Sensor 06002M is what I’m looking for, for an outside sensor. But it uses 433mhz signal. Can I add the Sonoff RF BridgeR2 to HA locally then add the AcuRite sensor to it and be able to see the temp and humidity sensors in HA? Or is there a different device that would work better to add the Acurite Sensor to HA?
I think you better buy an RTL-SDR (if you don’t know what it is, search the forum)
I’d second @francisp 's suggestion. An RTL-SDR (and even a micro version) is far more reliable. One thing to be certain, don’t just plug it into the computer directly, locate the RTL-SDR at least six inches away from the computer, using a short USB extender cable.
Thanks will look into it.
I got a 433 weather station (gifted to me) and I got an sdr dongle…
How do I integrate the two? I’ve been fighting this for the past 3 days…
The weather station is:
and the dongle is:
https://www.amazon.es/gp/product/B00P2UOU72/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1
Help!
Thanks in advance guys!
