I’d like to add a button on the entity card for my covers in order to start an automation (set the cover to its “sun” position = ~20% opened).
What’s the best way to proceed?
I was just looking for the same. This one here comes close: GitHub - jcwillox/lovelace-paper-buttons-row: Adds highly configurable buttons that use actions and per-state styling.
Thanks a lot, exactly what I was looking for!
Here’s my result using extend_paper_buttons_row:
Code:
type: entities
entities:
- entity: cover.shutter_kitchen
secondary_info: position
extra_styles: |
paper-button:hover {
background-color: #242424;
buttons:
- tooltip: Open cover to sun position
icon: mdi:weather-sunset-down
styles:
button:
color: var(--primary-text-color)
margin-right: 4px
tap_action:
action: call-service
service: script.open_kitchen_shutter_to_sun_position
Hello @otiel
thank you for your code. Works fine for me, too. But have you managed to get the extra symbol greyed out, when the cover is at the sunset position?
I didn’t look into it, but if you manage to make it work, I’m interested!
Yes, I found out how to make it work. For your example you could try:
buttons:
styles:
button:
margin-right: 4px
tap_action:
styles:
button:
color: >-
{% if is_state_attr('cover.shutter_kitchen', 'current_position', 20) %}
lightgrey
{% endif %}
… assuming the position-attribute for your cover is “current_position” … Maybe you have to change this.
sorry if i revive this topic, but i couldn’t find anything regarding this problem.
i have installed “Paper Buttons Row” and tried your code, but when i click/tap on the added button/icon the cover detail page opens as popup (and the action is executed):
the 2nd row is 1:1 your code
what am i missing? ![]()
do i need to block the popup?
hopefully somebody still uses this great addition…
best regards
Peter
I’m still using it everyday, no issue. Show us your code.
type: entities
show_header_toggle: false
entities:
- entity: cover.buro
buttons:
- entity: light.buero
icon: mdi:autorenew
styles:
button:
margin-right: 8px
extra_styles: |
buttons:
styles:
button:
margin-right: 4px
tap_action:
as you can see in my gif in both rows i get the popup.
I’ve missed in first time in your gif, but you get an error shown at the bottom:
Action script.open_kitchen_shutter_to_sun_position night gefunden.
You need to create this script in order to define what should happen when you click on the button. For that, go to Settings > Automations & scenes > Scripts > Create New. Here’s mine for example:
yeah i know. but that’s not the problem.
now that i added the script there’s still a popup when i press the button:
Weird. ![]()
Are you on the latest version of Paper Buttons Row (2.2.0)?
yes, that’s correct!
I have the same issue. It started a couple weeks ago. Any time I click on the new button I created, the More Info dialog pops up.
Are you both on Home Assistant 2025.5? I’m still on 2025.4, maybe that explains it.
yep, i’m on 2025.5
Just updated to HA 2025.5, and I now have the same issue. It seems like a bug in paper-buttons-row. I’ve created an issue.
In the meantime, I’ve configured the following workaround:
tap_action on the entity so that the “more-info” dialog doesn’t open when clicking on a paper-button.hold_action to still be able to access the “more-info” dialog by holding click on the entity.Add the following to each of your entities:
- entity: cover.xxx
tap_action:
action: none
hold_action:
action: more-info
thank you, this worked, this is my code now:
type: entities
entities:
tap_action:
action: none
hold_action:
action: more-info
buttons:
- entity: input_boolean.cover_buro_auto
tap_action:
action: toggle
state_icons:
"off": mdi:autorenew-off
"on": mdi:autorenew
styles:
button:
margin-right: 4px
Paper Buttons Row 2.2.1 available today fixes the issue. ![]()
