The input_text
helper currently has an initial
option which resets the field to the initial
value every time HA restarts. I think it would be advantageous for users to also have a “default” option which does not reset the field and instead functions as sort of a placeholder when the field is empty.
Currently any input_text
field that has never received any input shows a state of unknown
. However, I think it would be valuable to have control over that and be able to choose an initial default state and have it display something other than unknown
. It would be similar to the initial
option but it would not reset the field when HA restarts. Instead it would only show the default value when the user hasn’t entered anything into the field. An option to display the default state when everything has been deleted from the field could also be added but I personally wouldn’t want this to happen automatically.
A working example of this would be one of the ways I use the state
of several input_text
helpers to control the label
attribute
of the custom:tabbed-card
. I use the custom:decluttering-card
for different instances to pass a variable to signal which group of input_text
helpers should be used to label that instance of the custom:tabbed-card
. Then instead of having to change the yaml, I click a button which brings up a pop-up and I just change the input_text
field which in turn changes the tab label.
What I would like to do is create a default value for the input_text
helpers that I do not enter a value for (or maybe that I delete the value for and leave blank). The initial
option does that, however, if I enter a value into the input_text
field and then restart HA it will change back to the initial
value which I don’t want it to do. The solution would be to add an option to choose a default value or an option not to have the initial
value override an entered value when HA restarts.
I know I could use a template to achieve this but that means I would have to create a separate template sensor for each instance which is a lot to do just to achieve this. I think adding the option as a new feature would make more sense.
