Some sensors give realy strange reading like after a device reboot their count goes to 0 or if a seonsor is not avaible it might go to 0 then back to the proper value. If we could add a filter helper that we could filter the values coming from the sensor. IE data cannot have changed more than X% or X value. When Sensor is not available keep reporting the last value.
There is a filter helper, does this not work for you?
I had no clue, is this by the config only? is there no UI for this?
Not yet, it’s in construction so for the moment it’s unfortunately yaml only.
well the fact that it exists is awesome!!!
Is there a proper way to remove this form the WTH category? As my inability to RTM on filters makes this posting moot!
