oherrou
November 7, 2018, 7:39pm
42
I’m using the above setup to retrieve value of my linky at specific hour (halfhourly_xx_yy_consumption).
I would like to see my electricity consumption overtime, so I would like to plot it on a graph where each half hour the current consumption is plot. I searched about that but I was not able to find documentation about. Can one of you help me ?
Edit: I’ll give more information about what i’m trying to do.
The linky components give the consumption during the last 30min, so there is 48 points on the graph. The graph could either be a bar graph or it might link every dot with a line. If you have information about both bar and line graph, it will be great
radar
(Radar)
November 9, 2018, 10:13pm
43
Can someone explain how to add this sensor?
Thanks.
grea09
(Antoine Gréa)
January 25, 2019, 4:33pm
44
Ehlo, I haven’t seen there was an official component and I just used the custom one until I took on me to make a component more properly coded. I made something that seems to work in my case and I aim to redo the custom card form a better data display (lots of charts).
Here is the configuration needed:
- platform: linky
username: !secret linky_username
password: !secret linky_password
peak_hours:
- ["07:00","14:00"]
- ["17:00","02:00"]
peak_hours_cost: 0.1761
offpeak_hours_cost: 0.1291
It makes a sensor like this:
I may provide the code if people want it and even go to the troubles of making a PR but only if there’s enough demand. Might even make the card official if they accept it.
BTW: The monthly evolution is corrected only by actually making another request (since current month isn’t finished) so I made it to compare to the same month last year.
oncleben31
(Oncleben31)
January 26, 2019, 1:29pm
45
I like the way the sensor is structured. Can you share your work.
I think we should push for a PR as the current official component is very (too?) simple.
grea09
(Antoine Gréa)
January 28, 2019, 1:56pm
46
I just openned a PR here .
I’ll try to make a card that goes with it. The best thing would be to make it actually work in general and have an energy cosumption card. The problem is that other people actually got a continious sensor for power cosumption and can rely on history while the Linky API makes it impossible to get the consumption in real time (due to limitations on Linky itself).
I’ll try to see if there’s a workaround for this.
grea09
(Antoine Gréa)
January 28, 2019, 4:44pm
47
For now I ported the old custom component to my version of the sensor.
//import 'https://unpkg.com/@google-web-components/google-chart/google-chart.js?module';
class LinkyCard extends HTMLElement {
set hass(hass) {
if (!this.content) {
const card = document.createElement('ha-card');
const link = document.createElement('link');
link.type = 'text/css';
link.rel = 'stylesheet';
link.href = '/local/custom_ui/linky-card.css?v=31';
card.appendChild(link);
this.content = document.createElement('div');
this.content.className = 'card';
card.appendChild(this.content);
this.appendChild(card);
const entityId = this.config.entity;
const state = hass.states[entityId];
const stateStr = state ? state.state : 'unavailable';
const attributes = state.attributes;
this.content.innerHTML = `
<div class="hp-hc-block">
<google-chart
type='pie'
options='{"title": "${this.config.title}", "pieHole": 0.6}'
cols='[{"label":"Heures", "type":"string"}, {"label":"Consomation", "type":"number"}]'
rows='[["Pleines", ${Number.parseFloat(attributes.peak_hours).toFixed(1)}],["Creuse", ${Number.parseFloat(attributes.offpeak_hours).toFixed(1)}]]'>
</google-chart>
<span class="conso-hc">${Number.parseFloat(attributes.offpeak_hours).toFixed(1)}</span><span class="conso-unit-hc"> ${attributes.unit_of_measurement} <span class="more-unit">(en HC)</span></span><br />
<span class="conso-hp">${Number.parseFloat(attributes.peak_hours).toFixed(1)}</span><span class="conso-unit-hp"> ${attributes.unit_of_measurement} <span class="more-unit">(en HP)</span></span>
</div>
<div class="cout-block">
<span class="cout" title="Coût journalier">${Number.parseFloat(attributes.daily_cost).toFixed(2)}</span><span class="cout-unit"> €</span><!--FIXME: From yaml config or glabal setting--!>
</div>
<div class="clear"></div>
<span>
<ul class="variations-linky right">
<li><span class="ha-icon"><ha-icon icon="mdi:flash"></ha-icon></span>${Math.round(attributes.peak_offpeak_percent)}<span class="unit"> % HP</span></li>
</ul>
<ul class="variations-linky">
<li><span class="ha-icon"><ha-icon icon="mdi:arrow-right" style="transform: rotate(${(attributes.monthly_evolution < 0) ? '45' : ((attributes.monthly_evolution == 0) ? "0" : "-45")}deg)"></ha-icon></span>${Math.round(attributes.monthly_evolution)}<span class="unit"> %</span><span class="previous-month">par rapport à ${new Date((new Date().getTime()) - 365*60*60*24*1000).toLocaleDateString('fr-FR', {month: "long", year: "numeric"})}</span></li>
</ul>
</span>
<div class="week-history clear">
${Object.keys(attributes.daily.slice(2, 7)).map((day, index) => `
<div class="day">
<span class="dayname">${new Date((new Date().getTime()) - day*60*60*24*1000).toLocaleDateString('fr-FR', {weekday: "long"}).split(' ')[0]}</span>
<br><span class="cons-val">${Number.parseFloat(attributes.daily[day]).toFixed(1)} ${attributes.unit_of_measurement}</span>
</div>`).join('')}
</div>`;
setConfig(config) {
if (!config.entity) {
throw new Error('You need to define an entity');
this.config = config;
// @TODO: This requires more intelligent logic
getCardSize() {
return 3;
customElements.define('linky-card', LinkyCard);
This is still a work in progress but it works for me.
Include it like this:
type: 'custom:linky-card'
entity: sensor.linky
Here’s the result so far:
Tell me if you use it or if you have any issue with it
oncleben31
(Oncleben31)
February 3, 2019, 5:19pm
48
I’m testing the linky component by @grea09
In found an error due to a division by zero:
self._attributes["monthly_evolution"] = (
1 - ((self._lk.monthly[0][CONSUMPTION]) /
(self._lk.compare_month))) * 100
I’ve modified the code to bypass the error. It’s seems OK but I didn’t complete the custom card integration to do a complete check:
if self._lk.compare_month == 0:
self._attributes["monthly_evolution"] = 0
else:
oncleben31
(Oncleben31)
February 3, 2019, 5:24pm
49
About the “not continuous” sensor type. @grea09 perhaps we can create a fake one with a one day delay.
Imagine we are Tuesday 00:00. You take the value of Monday half hour by alf hour. This way it create a pseudo continuous sensor with step of half hour.
Do you think it cover what you have in mind ?
grea09
(Antoine Gréa)
February 4, 2019, 8:13am
50
I had this in mind and I almost coded it but I see a couple of problems with this:
Imagine wanting to make an automation on cosumption. This will trigger one day after the fact.
It might not be obvious to the user that there is a one day offset in history.
It becomes impossible to correlate the consumption with other measurements.
I think it might be better to simply hack the recorder into storing the value yesterday in the database.
grea09
(Antoine Gréa)
February 4, 2019, 8:14am
51
Thanks ! I’m updating my PR with that.
Bry
February 5, 2019, 5:24pm
52
Will this be in the next home assistant version realease ?
grea09
(Antoine Gréa)
February 7, 2019, 7:22am
53
Depends on the owners of HA. Usually they are quite demanding on the code and especially on improvements. I think it will need 2-3 releases as usual.
oncleben31
(Oncleben31)
February 7, 2019, 8:24pm
54
Feedback on your implementation of the custom card.
Currently Enedis website is down and the custom component raise an error during HA reboot. The Linky custom card is at the top of a view and all other cards on the same view are not displayed. I don’t know if its due to the card or Home Assistant front end.
oncleben31
(Oncleben31)
February 8, 2019, 8:31am
55
Do you need help for making the PR progress ?
grea09
(Antoine Gréa)
February 8, 2019, 9:15am
56
I fixed that a bit ago: here’s the new card.
set hass(hass) {
if (stateStr == 'unavailable') {
<div id="states">
<div class="name">
<ha-icon id="icon" icon="mdi:flash" data-state="unavailable" data-domain="connection" style="color: var(--state-icon-unavailable-color)"></ha-icon>
<span style="margin-right:2em">Linky : Site Enedis.fr inaccessible</span>
</div>
</div>`
if (stateStr != 'unavailable') {
<google-chart
type='pie'
</google-chart>
</div>
</div>
<span>
</ul>
</ul>
</span>
${Object.keys(attributes.daily.slice(2, 7).reverse()).map((day, index) => `
<div class="day">
<span class="dayname">${new Date(new Date().setDate(new Date().getDate()-(6-Number.parseInt(day)))).toLocaleDateString('fr-FR', {weekday: "long"}).split(' ')[0]}</span>
<br><span class="cons-val">${Number.parseFloat(attributes.daily.slice(2, 7).reverse()[day]).toFixed(1)} ${attributes.unit_of_measurement}</span>
</div>`).join('')}
</div>`;
setConfig(config) {
getCardSize() {
return 3;
grea09
(Antoine Gréa)
February 8, 2019, 11:40am
58
I just updated the PR to something a bit better formated. If you happen to know what is left to do please tell me, I would appreciate.
Thanks in advance.
makai
February 10, 2019, 8:44am
59
oncleben31
(Oncleben31)
February 17, 2019, 8:22am
60
Do you have difficulties to fetch data with this custom component while you can log in the Enedis web UI and access all the data ?
I’ve this problem since few days.
There is an issue related to that raised on Github with the python module done by Pirionfr
grea09
(Antoine Gréa)
February 17, 2019, 8:24am
61
I have no problems here. I’m using the latest version.
Also Enedis.fr is very often broken for some reason.
