Just now this is the case (component and web UI KO) but yesterday I succeed to access the data thru the website and the HA component still fill the logs with the login error.
I will retry with the last modifications you have pushed in the PR.
They seem to have broken their own API for now…
I will try again latter and see if they update their website.
Example now. website is OK but not the component.
PirionFR seems to have found a workaround in the PR linked in my previous post. Using pyLinky 0.2.1 should be the answer.
I tried to change the pylink version in the custom component without any change on the issue.
I’m not sure the HA have taking it into account.
It’s work for me by updating to 0.2.1
I have to double check.
Just to be sure, you just changed in the custom component pylink the version in the line
REQUIREMENTS = ['pylinky==0.2.0']
Yes, I have made a custom component linky2.py with the latest code from the PR of grea09 and changed line 19 with :
REQUIREMENTS = ['pylinky==0.2.1']
Hope it will work for you!
It seems I have an error with fake-user agent module used by pylinky. I’ve this error:
2019-02-20 23:29:28 WARNING (SyncWorker_10) [fake_useragent] Error occurred during loading data. Trying to use cache server https://fake-useragent.herokuapp.com/browsers/0.1.11
File "/config/deps/lib/python3.6/site-packages/fake_useragent/utils.py", line 67, in get
context=context,
File "/usr/local/lib/python3.6/urllib/request.py", line 223, in urlopen
return opener.open(url, data, timeout)
File "/usr/local/lib/python3.6/urllib/request.py", line 526, in open
response = self._open(req, data)
File "/usr/local/lib/python3.6/urllib/request.py", line 544, in _open
'_open', req)
File "/usr/local/lib/python3.6/urllib/request.py", line 504, in _call_chain
result = func(*args)
File "/usr/local/lib/python3.6/urllib/request.py", line 1346, in http_open
return self.do_open(http.client.HTTPConnection, req)
File "/usr/local/lib/python3.6/urllib/request.py", line 1321, in do_open
r = h.getresponse()
File "/usr/local/lib/python3.6/http/client.py", line 1331, in getresponse
response.begin()
File "/usr/local/lib/python3.6/http/client.py", line 297, in begin
version, status, reason = self._read_status()
File "/usr/local/lib/python3.6/http/client.py", line 258, in _read_status
line = str(self.fp.readline(_MAXLINE + 1), "iso-8859-1")
File "/usr/local/lib/python3.6/socket.py", line 586, in readinto
return self._sock.recv_into(b)
socket.timeout: timed out
File "/config/deps/lib/python3.6/site-packages/fake_useragent/utils.py", line 166, in load
verify_ssl=verify_ssl,
File "/config/deps/lib/python3.6/site-packages/fake_useragent/utils.py", line 122, in get_browser_versions
File "/config/deps/lib/python3.6/site-packages/fake_useragent/utils.py", line 84, in get
raise FakeUserAgentError('Maximum amount of retries reached')
fake_useragent.errors.FakeUserAgentError: Maximum amount of retries reached
Any one with experience or skills to help find the root cause ?
Sorry can’t help you
That error probably means the servers are down again. I can querry them here.
Try with python3 -m pylinky -u [email protected] -p secret_password
I am working on doing a much better version of the component. I want to make it integrate with the new Utility metter. I also got 5 students of mine on the UI to add cards with more graphs option and allowing for use with generic cards.
I however need to modify the history of the sensor. I found how to do it but I want to do it properly and convince the core team to allow for the modification of the recorder component. I did so here. If you want to help try to vote for the request.
thx for the great job!
It would be very nice to integrate into the utility meter. As for the history it would be perfect to insert the data on the right date (so yesterday’s for data received today in Linky).
Keep up the good work
linky component doesn’t work, is there any update coming soon ?
thanks
I tried to bump pylinky to 0.3.1, I add to modify the code to configure the platform. Anyway it did not work. I try to use Pylinky directly and it works so the issue is not in enedis site but on the component. I did not try the built-in Linky component (which was bumped in 0.3.0 in dev).
still not working with the today update 0.89
linky: Error on device update!
File "/usr/local/lib/python3.7/site-packages/homeassistant/helpers/entity_platform.py", line 248, in _async_add_entity
await entity.async_device_update(warning=False)
File "/usr/local/lib/python3.7/site-packages/homeassistant/helpers/entity.py", line 348, in async_device_update
await self.hass.async_add_executor_job(self.update)
File "/usr/local/lib/python3.7/site-packages/homeassistant/util/__init__.py", line 224, in wrapper
result = method(*args, **kwargs)
File "/usr/local/lib/python3.7/site-packages/homeassistant/components/sensor/linky.py", line 87, in update
_LOGGER.debug(json.dumps(self._client.get_data(), indent=2))
File "/usr/local/lib/python3.7/site-packages/pylinky/client.py", line 202, in get_data
formatted_data[t] = self.format_data(self._data[t])
File "/usr/local/lib/python3.7/site-packages/pylinky/client.py", line 142, in format_data
start_date = datetime.datetime.strptime(data.get("periode").get("dateDebut"), "%d/%m/%Y").date()
AttributeError: 'NoneType' object has no attribute 'get'
I’ve find a solution in order to not have the errors with component “Linky Sensor” (embedded in Home-Assistant since v0.79): add optionnal (but undocumented) attribute “timeout”.
- platform: linky
username: !secret enedis_username
password: !secret enedis_password
timeout: 60
Regards,
Romain.
It’s working now, although I’v sometimes error like :
Impossible to decode response: Expecting value: line 1 column 1 (char 0) Response was: <!DOCTYPE HTML PUBLIC “-//IETF//DTD HTML 2.0//EN”> <html><head> <title>302 Found</title> </head><body> <h1>Found</h1> <p>The document has moved <a href=“https://espace-client-connexion.enedis.fr/auth/UI/Login?realm=particuliers&amp;goto=http%3A%2F%2Fespace-client-particuliers.enedis.fr%3A80%2Fgroup%2Fespace-particuliers%2Fsuivi-de-consommation%3Fp_p_cacheability%3DcacheLevelPage%26p_p_col_count%3D3%26p_p_col_id%3Dcolumn-1%26p_p_col_pos%3D1%26p_p_id%3Dlincspartdisplaycdc_WAR_lincspartcdcportlet%26p_p_lifecycle%3D2%26p_p_mode%3Dview%26p_p_resource_id%3DurlCdcHeure%26p_p_state%3Dnormal”>here</a>.</p> </body></html>
Update for sensor.linky fails
File “/usr/local/lib/python3.7/site-packages/homeassistant/helpers/entity.py”, line 220, in async_update_ha_state
await self.async_device_update()
File “/usr/local/lib/python3.7/site-packages/homeassistant/helpers/entity.py”, line 348, in async_device_update
File “/usr/local/lib/python3.7/concurrent/futures/thread.py”, line 57, in run
File “/usr/local/lib/python3.7/site-packages/homeassistant/util/init.py”, line 224, in wrapper
File “/usr/local/lib/python3.7/site-packages/homeassistant/components/sensor/linky.py”, line 81, in update
self._client.fetch_data()
File “/usr/local/lib/python3.7/site-packages/pylinky/client.py”, line 193, in fetch_data
self._data[t] = self.get_data_per_period(t)
File “/usr/local/lib/python3.7/site-packages/pylinky/client.py”, line 184, in get_data_per_period
data = self._get_data(_MAP[_RESSOURCE][period_type], start, end)
File “/usr/local/lib/python3.7/site-packages/pylinky/client.py”, line 98, in _get_data
raw_res = self._session.post(DATA_URL,
AttributeError: ‘NoneType’ object has no attribute ‘post’
Well here is my linky entity, there is nothing in attributes and the doc in components page is very poor…
I’m in the same situation as you, with the same mistakes you’re quoting above . If there was someone who could give us a little help please
