Hi!
My heat pump (brand IVT), is connected to HA with mqtt (autodiscovery). I would want to have some values added in the energy dashboard. Especially the heat energy comsumption and the warm water comsumption. I already use these values to track my daily consumption - that was easy with a helper.
But how can I make these accepted by the energy dashboard? I tried to create sensors and helpers that copied the values, but that didn’t help. I’m a newbie, so please explain as if I was a true beginner.
Thanks!
It must have the right device_class
EDIT: like this, in yaml
device_class: energy
state_class: measurement
and the correct state_class (total, total_increasing or measurement) …
I use
and that don’t seem to support state_class
I had already device_class: energy
Is the platform (template) wrong way to go?
/Fanan
yes, that’s the “legacy” mode (old) and does not use all the new implementations.
I would recommend that you go with the newer templateing mode (below an example)
template:
- sensor:
- name: "Solaredge Calculated m1 Import"
unique_id: "solaredge_calculated_m1_import"
icon: mdi:transmission-tower-import
unit_of_measurement: "kWh"
state_class: total_increasing
state: >
{% set measured_import = states('sensor.solaredge_m1_imported_kwh') | float(0) %}
{% set imported_before_meter_installation = 296.00 | float(0) %}
{{ (measured_import + imported_before_meter_installation) | round(3, 0) }}
availability: >
{{ states('sensor.solaredge_m1_imported_kwh') not in ['unknown', 'unavailable', 'None'] }}
- sensor:
- name: your_name
unique_id: 'unique_id'
unit_of_measurement: L
device_class: volume
state: >
{% set max_filllevel = 3000 | float(0) %}
{% set current_filllevel = states('sensor.oilfox_filllevelquantity') | float(0) %}
{% set fuelused = max__filllevel - current_filllevel | float(0) %}
{{ '{:.2f}'.format(fuelused) }}
availability: >
{{ states('sensor.oilfox_filllevelquantity') not in ['unknown', 'unavailable', 'None'] }}
Thanks! Now it’s working!
/Fanan
I was wrong. On the surface everything was ok. But the new entity don’t change - it’s still zero, which is far from the truth. What am I missing? This is my code (in my template.yaml):
- sensor:
- name: "Bergvärmens energiåtgång"
unique_id: "bergvarme_energiatgång"
state: >
{% set measured_import = states('sensor.supp_energy_heating') | float(2) %}
availability: >
{{ states('sensor.supp_energy_heating') not in ['unknown', 'unavailable', 'None'] }}
This code worked (finally):
Template:
- sensor:
- name: "Bergvärmen i kWh"
unique_id: "bergvarmen_i_kwh"
state: "{{ states('sensor.compr_cons_heating')|float(0) }}"
availability: "{{ states('sensor.compr_cons_heating')|is_number }}"
