tl;dr Add another field to the context object:
Field | Description |
purpose | Custom identifier passed through from the corresponding service call. |
Currently, an event looks like this (I changed an input_text entity in my Lovelace dashboard):
event_type: state_changed
entity_id: input_text.test
old_state:
state: "123"
attributes:
editable: true
min: 0
max: 100
pattern: null
mode: text
friendly_name: test
last_changed: "2024-01-26T10:32:37.592501+00:00"
last_updated: "2024-01-26T10:32:37.592501+00:00"
context:
parent_id: null
user_id: null
new_state:
state: "1234"
attributes:
editable: true
min: 0
max: 100
pattern: null
mode: text
friendly_name: test
last_changed: "2024-01-26T10:33:06.920615+00:00"
last_updated: "2024-01-26T10:33:06.920615+00:00"
context:
parent_id: null
user_id: e07234cbc3f24760b38e50ff83dae4f8
origin: LOCAL
time_fired: "2024-01-26T10:33:06.920615+00:00"
context:
parent_id: null
Let’s look at the context part. The user_id
is filled because I changed the value of the text in the UI.
A context object contains the following fields (from: Home Assistant Context | Home Assistant Data Science Portal):
context_id | Unique identifier for the context. |
user_id | Unique identifier of the user that started the change. |
parent_id | Unique identifier of the parent context_id that started the change. |
If something is listening to this event, getting more context from it is hard. It would be helpful to add a purpose to the corresponding service call:
service: light.turn_on
entity_id: light.hue_color_lamp_1
data: {}
purpose: auto_lighting
And the event fired would look like this:
data: {...}
origin: LOCAL
time_fired: "2024-01-26T10:43:06.920615+00:00"
context:
parent_id: null
user_id: null
Example:
Consider a lighting workflow that monitors state_changed
events. In this scenario, the workflow recognizes that if the change in light state is a result of a service call initiated by the same workflow, it should disregard the event. Events lacking the purpose: auto_lighting
attribute could be identified as manual changes made outside the automated lighting system.
