Hi @Tamsy
Thanks for your reply.
My linux skills are a bit limited, but I usually go to /etc/nework/interfaces
and configure the IP settings.
I got a bit scare when I configured the IP from HA webUI and them I found the interfaces file empty.
I was planning to use for example .10 for HA and .11 for Ubiquity.
# Static IP address
auto eth0
iface eth0 inet static
address 172.31.1.10
netmask 255.255.255.0
network 172.31.1.0
broadcast 172.31.1.255
gateway 172.31.1.1
# Virtual interface
# Static IP address
auto eth0:0
iface eth0:0 inet static
address 172.31.1.11
Heres the output :
1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN group default qlen 1000
link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00
inet 127.0.0.1/8 scope host lo
valid_lft forever preferred_lft forever
inet6 ::1/128 scope host
2: eno1: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc pfifo_fast state UP group default qlen 1000
link/ether 1c:69:7a:a1:73:01 brd ff:ff:ff:ff:ff:ff
inet 172.31.1.10/24 brd 172.31.1.255 scope global noprefixroute eno1
inet6 2001:818:e22b:8e00:2be3:3d0d:a393:ee33/64 scope global dynamic noprefixroute
valid_lft 86352sec preferred_lft 3552sec
inet6 fe80::f0f1:b0fd:267:7a60/64 scope link noprefixroute
3: docker0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc noqueue state UP group default
link/ether 02:42:b8:26:c5:44 brd ff:ff:ff:ff:ff:ff
inet 172.17.0.1/16 brd 172.17.255.255 scope global docker0
inet6 fe80::42:b8ff:fe26:c544/64 scope link
7: vethedcbc86@if6: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc noqueue master docker0 state UP group default
link/ether d2:63:86:3c:0c:fc brd ff:ff:ff:ff:ff:ff link-netnsid 0
inet6 fe80::d063:86ff:fe3c:cfc/64 scope link
8: hassio: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc noqueue state UP group default
link/ether 02:42:a0:c5:42:1e brd ff:ff:ff:ff:ff:ff
inet 172.30.32.1/23 brd 172.30.33.255 scope global hassio
inet6 fe80::42:a0ff:fec5:421e/64 scope link
10: veth75476cb@if9: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc noqueue master hassio state UP group default
link/ether 32:92:70:75:3a:56 brd ff:ff:ff:ff:ff:ff link-netnsid 0
inet6 fe80::3092:70ff:fe75:3a56/64 scope link
12: vetha08a952@if11: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc noqueue master hassio state UP group default
link/ether 42:eb:76:07:db:45 brd ff:ff:ff:ff:ff:ff link-netnsid 1
inet6 fe80::40eb:76ff:fe07:db45/64 scope link
14: veth6baa7e6@if13: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc noqueue master hassio state UP group default
link/ether fa:55:5e:85:cd:2c brd ff:ff:ff:ff:ff:ff link-netnsid 2
inet6 fe80::f855:5eff:fe85:cd2c/64 scope link
16: veth14d6592@if15: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc noqueue master hassio state UP group default
link/ether 6e:d8:64:68:c2:4a brd ff:ff:ff:ff:ff:ff link-netnsid 3
inet6 fe80::6cd8:64ff:fe68:c24a/64 scope link
18: veth5485225@if17: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc noqueue master hassio state UP group default
link/ether 2e:02:e1:71:41:99 brd ff:ff:ff:ff:ff:ff link-netnsid 4
inet6 fe80::2c02:e1ff:fe71:4199/64 scope link
root@domus:~# docker network ls
NETWORK ID NAME DRIVER SCOPE
791af569ff8b bridge bridge local
f909a24cd35c hassio bridge local
a3883cedffe2 host host local
57908c517ad6 none null local
I understand some people might say I should separate things, but to be honest I think the NUC is powerfull enough to run other things.
Ideally how can I configure the 2 IPs without messing HA supervisor?
