When the service call scene.turn_on
is invoked in the basic case, either with a scene created in the UI or using scene.create
with a list of entities, it is applied to all items at once. I would like the option to stagger the application to each entity. The entities would be activated in the order listed, the first immediately, the second after the specified stagger time, then the third after the same stagger time and so on. The stagger time should also apply at the end before the scene finished running.
If combined with transition (which it does not have to be), the stagger time is the delay period (in seconds or milliseconds) between the start of successive transitions. the stagger time may be lass than, equal to or greater than the transition time.
The default order would be as the entities are listed but it would be useful to have a reverse_order option so that I can use a list of entities from a blueprint in a scene.create but apply the scene in the reverse order (I generally use the forward order to turn them on and the reverse order to turn them off).
If this feature request is implemented, the YAML for activation might appear as follows:
service: scene.turn_on
entity_id: scene.romantic
transition: 20 # optional, default 0
stagger_time: 5 # NEW optional, default 0
order_reversal: false # NEW optional, default false
