Add a static route HomeAssistant on Rasp5
Hello, I have a connection to internet via a static IP. But I want to set a additional static route in my homeassistant and use a different gateway like:
I used the addon “Terminal & SSH” but there is no option for “uncheck the protected mode”. So I can not use the command " nmcli" to set the route.
How can I set a static route?
The protection mode should be a setting on the same tab as the start button for the addon.
That is the wrong one.
afbeelding
This is the good one
afbeelding
Never realized that there were two different SSH addons. Nice to know! :slight_smile:
Thanks francisp,
I have ssh adv. already tried. I can also start it, but when I open the web UI the following messages appear.
start
Probably because you did not uninstall the other one.
Sorry, it was the wrong password. SSH works.
