Add a way to change default display resolution for the video output on haos
add a way to change default display resolution for the video output on haos.
because when y start haos on rpi4 and odroid they use fixed default resolution.
if your screen not support this resolution you don’t have anything on the screen…
idealy is to detect the resolution base on the screen EDID.
with tool like:
get-edid | parse-edid
or hwinfo :
# hwinfo --monitor
15: None 00.0: 10002 LCD Monitor
  [Created at monitor.125]
  Unique ID: rdCR.03oFM_ZXju6
  Parent ID: _Znp.9itj+PNW6b7
  Hardware Class: monitor
  Model: "ASUS VW161"
  Vendor: ACI
  Device: eisa 0x16a1 "ASUS VW161"
  Serial ID: "88LMTN020916"
  Resolution: 720x400@70Hz
  Resolution: 640x480@60Hz
  Resolution: 640x480@67Hz
  Resolution: 640x480@72Hz
  Resolution: 640x480@75Hz
  Resolution: 800x600@56Hz
  Resolution: 800x600@60Hz
  Resolution: 800x600@72Hz
  Resolution: 800x600@75Hz
  Resolution: 832x624@75Hz
  Resolution: 1024x768@60Hz
  Resolution: 1024x768@70Hz
  Resolution: 1024x768@75Hz
  Resolution: 1280x720@60Hz
  Resolution: 1280x720@75Hz
  Resolution: 1360x768@60Hz
  Year of Manufacture: 2008
  Week of Manufacture: 33
  Detailed Timings #0:
     Horizontal: 1360 1424 1536 1792 (+64 +176 +432) +hsync
       Vertical:  768  771  777  795 (+3 +9 +27) +vsync
    Frequencies: 85.50 MHz, 47.71 kHz, 60.02 Hz
  Driver Info #0:
    Max. Resolution: 1360x768
    Vert. Sync Range: 55-75 Hz
    Hor. Sync Range: 30-85 kHz
    Bandwidth: 85 MHz
  Config Status: cfg=new, avail=yes, need=no, active=unknown
  Attached to: #12 (VGA compatible controller)
Don’t forget to vote for your own request :slight_smile:
i found partial solution.
use usb key, formated FAT32 and named CONFIG, with file cmdline.txt with console=tty0.
Yes please! This would be very helpful when one does not have a monitor to use but can use i.e. a capture card to get video from. However if the capture card only grabs what it can from the source, which in RPI400 case is 4K, you’re forced to that resolution with no option to change it from HA.
