Add ability to manually trigger an automation trigger from the automation editor
When creating advanced automations, it’s not unusual to have multiple triggers, each of which can have a trigger id that is then used in the actions.
At present, it’s difficult to test these automations as they will often fail unless triggered by one of the triggers. Just using the “Run Actions” command doesn’t set the trigger id, etc.
It would be great if you could, in the automation editor, click on the 3 dot menu next to a trigger and “Run actions using this trigger”. That would enable these automations to be tested properly.
Set states (etc) in Developer Tools to trigger automations for testing.
