Is there a way to animate the image that’s grabbed using this method? All I’ve got is a still when I use this technique. Also, I’ve noticed that if I change the link from _WKR_PRECIPET_SNOW.gif to _WKR_COMP_PRECIPET_SNOW.gif I get a little more detail, but it also shows the circles for radar range; do you know a file naming convention or other way to choose which ovelays are included on the image? Ideally I’d like to find a way to imbed the 10-frame animate image with the city names and roads overlay enabled.
I’ve created a camera component that returns an animated image, the details are at this thread:
The COMP image is a fall-back that is used when the actual site requested is not available. It uses surrounding radars (where available) to try to build a composite image that covers the target area.
I haven’t figured out a way to add the overlays; they don’t seem to publish them.
Let me know if you have any more questions.
This was working beautifully until very recently- perhaps after the 0.93.1 HA upgrade. As shown I have both wunderground and NOAA in there; about 60% of the time for wunderground and 100% of the time for NOAA I’m getting the broken link icon, and the camera shows “idle”. No related errors in the log. I tried playing around with content_type but it didn’t really seem to change anything. Has anyone else noticed a change?
One more thing… tried adding an Iframe card, which works, but it only displays the upper left hand corner of the weather map. There doesn’t seem to be any control over scale.
Yea, I am getting the broken icon quite often as well. This morning it has been that way all morning and I tried to go to the URL itself, and that too failed to open. I would venture to guess this is more of an issue with weather underground than HA.
FWIW, I went back through the instructions and the URL is quite different now. I wonder if they changed something on their side. Using the new URL, its at least working at the moment.
Considering that there is now a free, feature-rich API of rainviewer.comavailable here, would it make sense (is it possible?) to integrate this as an optional overlay on the “normal” map?
As e.g. seen here, I suppose this may be relatively easy to add to the existing leaflet/openstreetmap code? If so, I think it should also be possible to adjust the colormap of the radar image with respect to the used theme.
Hi Dave thanks for helping me - and for your constant help with others on this forum, it hasn’t gone unnoticed.
I tried your suggestion - it probably would have worked but i could not find a Canadian provider that produces still images of the radar like BOM does.
Try your local news channel’s website. That’s what I do because I liked the look and it’s a familiar image for the family. I’m In the States, but thought you might have luck this way if you haven’t tried it yet.
