Recently I’ve switched from a Homey to HA and now Christmas comes. For my in-house Christmas lights i have a couple of AC-1000 switches laying around from the vendor KlikAanKlikUit (KAKU). These operate on the 433Mhz band.
With Homey it was pretty easy to bind them to the Homey. Now I have a RFXCom attached to my HA instance which works for my Novy hood and my ASA screens.
I have attached the RFXcom to my laptop and came to the conclusion it is on the protocol AC what I need to do. I programmed them and added the switches to RFXCom. For example:
Packettype = Lighting2
subtype = AC
Sequence nbr = 17
ID = 0000001 decimal:1
Unit = 1
Command = On
Signal level = +10 dBm
9-12-2022 12:00:24:958= 0402011100
Packettype = Receiver/Transmitter Message
subtype = Transmitter Response
Sequence nbr = 17
response = ACK, data correct transmitted
And it works too, sending the ON command turns the switch on and with the OFF command it goes off. I just don’t know how I can convert this to an Event Code to add it to HA. I have been reading the manuals but can’t seem to understand how this works. Should be pretty easy but as I said, just can’t seem to figure it out.
