Add and Subtract States Sensor
This blueprint will help you create sensors which hold the value created by adding and/or subtracting the numeric states of one or more entities, either from the states of other entities or from a static base value.
This sensor will follow the equation A + B - C = D, where D is the output of this sensor.
blueprint:
  author: Didgeridrew
  homeassistant:
    min_version: 2025.1.0
  name: Add and Subtract State Values
  description: |
    Creates a sensor which holds the value created by adding and/or subtracting the state values of one or more entities, or from a static base value.
  domain: template
  input:
    base_value:
      description: |
        A static value that selected state values will be added to or subtracted from (optional, defaults to 0).
        In the equation A + B - C = D, this input will define A.
      default: 0
      selector:
        number:
          mode: box
          min: -5000
          max: 5000
    sum_entities:
      description: |
        The states of all entities given in this input will be added to together, then added to the Base Value.
        In the equation A + B - C = D, the sum of these entities' states' will define B.
      default: "sensor.none"
      selector:
        entity:
          multiple: true
          filter:
            - domain:
                - sensor
                - number
                - input_number
                - counter
    diff_entities:
      description: |
        then subtracted from the sum of the Base Value and Additive Entities.
        In the equation A + B - C = D, the sum of these entities' states' will define C.
      selector:
        entity:
          multiple: true
          filter:
            - domain:
                - sensor
                - number
                - input_number
                - counter
    availability_method:
      description: |
        Controls how availability is handled. When using the "all" method, the sensor will be available only if all referenced entities
        have valid state values. The "any" method will allow the sensor to return a value as long as 1 or more entities have valid state values.
        This input will default to "all" if no value is specified.
      default: all
      selector:
        select:
          options:
            - all
            - any
variables:
  base: !input base_value
  sum_ents: !input sum_entities
  diff_ents: !input diff_entities
  a_method: !input availability_method
  state: |
    {% set base = 0 if base is undefined else base %}
    {{ base + this.attributes.to_add - this.attributes.to_subtract }}
  attributes:
    base_value: "{{base}}"
    to_add: |
      {% if sum_ents is not none and sum_ents != 'sensor.none' %}
        {{ states(sum_ents)|float(0) if sum_ents is not list else sum_ents|select('has_value')|map('states')|map('float',0)|sum }}
      {% else %}
        0
      {%endif%}
    to_subtract: |
      {% if diff_ents is not none and diff_ents != 'sensor.none' %}
        {{states(diff_ents)|float(0) if diff_ents is not list else diff_ents|select('has_value')|map('states')|map('float',0)|sum }}
      {% else %}
        0
      {%endif%}
  availability: |
    {% set u = union(diff_ents,sum_ents) %}
    {% if a_method == 'all' %}
      {{ u|reject('has_value')|list|count == 0 }}
    {% else %}
      {{ u|select('has_value')|list|count > 0 }}
    {% endif %}
Template Blueprints are currently (2025.07) only available through YAML configuration. You can find more details about how to use them at: HA Docs - Templates - Using Blueprints
Once you have installed the blueprint, you can use the following configurations as examples to create working sensors in your configuration.yaml file:
template:
  - name: Subtract Counter from sum of Example 1 & 2
    unique_id: bp_add_subtract_0001
    use_blueprint:
      path: Didgeridrew/add-and-subtract-states-sensor.yaml
      input:
        base_value: 0
        sum_entities:
          - "sensor.example_1"
          - "sensor.example_2"
        diff_entities: "counter.example_counter"
        availability_method: all
Hi, Import is not working, telling me unsupported Domain
I can’t reproduce your issue… I have deleted my previous import, restarted HA, and re-imported via the link 3 times without issue.
Hello Matthias Vanselow,
Is your Home Assistant at least that version or newer?
Can I use this blueprint to correct the deviation of my temperature sensor using a offset value? I am currently using a helper.
Hello Fred54,
Look at Compensation - Home Assistant
Yes, it is 2025.7.1
I just fixed an issue with this blueprint, refreshed the import button link, and confirmed that it is working for me.
If it still doesn’t work for you make sure to check any browser extension you are using that may be blocking it and take a look at the My integration docs to make sure your HA instance is set up properly to use the link.
You can also just install it manually.
