trying to show the frontend the Ikea covers are moving, we find there is no attribute ‘opening’ or ‘closing’.
Having tried to template that based on last_changed, tells us this only changes from opening to closing, and (not vice versa, and) not in between.
I have also tried the trend binary sensor, but that only changes when an actual motion is started, again, not when stopped…
see: How to template a 'covering' cover
so, please consider adding the attribute in core, to allow the frontend to show ‘Opening’, and ‘Closing’.
thanks!
javicalle
(javicalle)
June 29, 2020, 10:32pm
2
I think that can be achieved just implementing two properties: is_opening(self) and is_closing(self).
Maybe tracking current position against the set_position value you can determinate if cover is opening or closing:
@property
def is_opening(self):
return set_position_value > self._device_data.current_cover_position
@property
def is_closing(self):
return set_position_value < self._device_data.current_cover_position
The set_position_value value will need to be ‘stored’ to compare against.
Also, the value need to be updated in every call to open, close & stop cover.
could you please post that at the bug issue https://github.com/home-assistant/core/issues/37223 , maybe the author of the integration can assist
