Add background image to horizontal stack?
I can not get an image to show as background on the horizontal stack in either of the below card configs. All shows well but not the image. I specifically dont want it to show up on the full card, which is possible setting the style on the top hierarchy of the card. Please have a look what is wrong?:
  - type: custom:stack-in-card
    keep:
      background: true
    cards:
      - type: horizontal-stack
        style: |
          ha-card {
            background: url('/local/images/vijver.jpg');
        cards:
          - type: custom:button-card
            template: button_switch
            entity: switch.vijverpomp_links
            triggers_update: sensor.vijverpomp_links_actueel
            entity: switch.vijverpomp_rechts
            triggers_update: sensor.vijverpomp_rechts_actueel
            color_type: blank-card
      - type: entities
        entities:
          - entity: input_boolean.vijverpompen_alterneren
            secondary_info: last-changed
          - entity: binary_sensor.vijverpompen
          - entity: sensor.vijverpompen
or
  - type: entities
    entities:
      - type: custom:hui-horizontal-stack-card
        style: |
          ha-card {
            background-size: cover;
        cards:
I don’t think it is possible. Stacks don’t have a background or border.
thats too bad really. I can get it to show as an additional picture card of course:
  - type: entities
    entities:
      - type: custom:hui-element
        card_type: picture
        image: /local/images/vijver.jpg
        style: |
          ha-card {
            box-shadow: none;
            margin: -16px -16px 0px -16px;
which amounts to the same results as when using a header:
  - type: entities
    header:
      type: picture
    entities:
or, as said as background for the full card, but as you can see that would require some more styling on the individual elements:
  - type: entities
    style: |
      ha-card {
    entities:
really ‘need’ the background for a stack… maybe Ill check with Romrider if he is willing to consider a FR :wink:
Yeah my workaround is to use an entities card instead of a vertical stack (using custom-hui-element for the contained cards). But there’s not really a solution for a horizontal stack.
yes, thats what I do too (never use the vertical-stack anymore unless I want the horizontal separation between the cards explicitly).
Added a picture glance to the options:
but that too isnt as expressive as I would like it to be. Btw, what horrid tooltips are displayed on that card, never noticed that before:
This should work:
            mode: horizontal
            title: test
            keep:
              background: true
            style: |
                ha-card {
                  background: blue;
            cards:
                entity: sun.sun
                aspect_ratio: 1/1
thanks, and yes, it does, see the bottom card, in comparison to the glance card art the top, and the middle entities card, with a mod-card mod:
type: entities
entities:
    card_type: custom:mod-card
    style: |
      ha-card {
    card:
      cards:
which immediately shows the image isn’t to suited for a background, considering the text color to pick :wink:
below is my code for this. As you can see I am using opacity for the cards, but that is too active, as it also changes the icon, and text on the card. Id really only want the background of the button cards to be more transparent, but at the same time have the icon and text be regular 100% visible…
mode: horizontal
title: Vijverpompen
keep:
  background: true
style: |
  ha-card {
    color: darkblue;
cards:
    template:
      - button_switch
      - spin
    style: |
      ha-card {
        box-shadow: none;
        opacity: 0.9;
    template:
      - button_switch
      - spin
    style: |
      ha-card {
        box-shadow: none;
        opacity: 0.9;
Awersome feature, unfortunally it doesn’t work for me even if i paste the exacte same code:
Can anyone help please?
What feature, that code is working as expected outside the card mod portion.
you could try card-mod
here’s an example of what i did with my custom weather card.
type: custom:weather-card
theme: Animated Weather Card
entity: weather.forecast_home
show_forecast: false
number_of_forecasts: ‘5’
card_mod:
style: |
ha-card {
color: #EFEFEF;
min-height:100%;
background:url(https://www.eea.europa.eu/themes/biodiversity/state-of-nature-in-the-eu/state-of-nature-2020-subtopic/image_print) rgba(50, 50, 50, .35);
background-size: 115% 115%;
background-repeat: no-repeat;
background-position:center -0px;
background-blend-mode: multiply;
Screenshot 2022-10-27 134929
