Hi, could be possible add an option for choosing the different HDMI sources on Samsung smart tv Integration?
Currently is possible to choose different sources but only 1 option HDMI, it makes my tv jump to the next HDMI it had last boot time, or keeps same HDMI source if I not define it.
For instance:
I use automation for turning on the tv, and set hdmi 2 where I have connected my ps4.
call service → media player tv turn on → call service → media player select source → HDMI
It will turn on tv and jump to the next HDMI that was on last boot, so if left on HDMI 1, jumps to HDMI 2, or if left on HDMI 3, jumps to HDMI 1.
If I do same script as before but without calling service media player select source, it turins on on same HDMI as last boot.
So… I need be able to choose the proper HDMI source but nothing works.
I tried this kind of source too, but no luck: ST_HDMI1, ST_HDMI2, ST_HDMI3
I have a similar question. The good news is a have a Logitech Harmony Hub too and this is easier with it, but one more tech jump and I like to minimize the steps for troubleshooting later. I have 4 HDMI ports. This one only goes to the main HDMI port ( the HDMI 2A) on my TV connected to the Xbox for obvious reasons. I have a DVR, Nintendo and an Apple TV. I would also like Friendly Name for these 4 sources.
source_list:
- TV
- HDMI
is_volume_muted: false
device_class: tv
friendly_name: Samsung QN90AA 55 TV
supported_features: 20409
I would also really like this feature. My Q90R only shows HDMI & TV in the sources. There is another Samsung TV integration but it’s seemingly no longer maintained and while this DOES support specifying a specific source, it seems broken and no longer maintained.
Is anyone investigating this? I have an S95BA that only shows “TV” and “HDMI” as sources in the HA media player entity. Since the Samsung iR remote control is garbage (4+ button presses to change inputs: home, left, down, down, right however many times, enter), I was really hoping HA would offer a more direct solution.
Samsung firmware is overall the worst smart TV firmware I’ve ever encountered, so I’m steeled for the potential result of “the firmware doesn’t present that option”…
I believe you need to use the Samsung Tizen (if this is a Tizen-based TV) integration and also use smarttings to get the ability to select inputs other than “HDMI”. Look here:
That integration supports sending the extra keycodes for specific input.
