add a cooldown for automations,
eg. cooldown: 15 minutes
Means if the automation was trigger within the last 15 minutes, do not trigger it again.
and
a once per day cooldown would be awesome too!
and
You can accomplish this already. Add a service call to turn the automation itself off, then create another automation that turns the first automation back on if itâs been off for a certain period of time.
Add to first automation (weâll assume itâs called automation1):
- service: automation.turn_off
entity_id: automation.automation1
Create a second automation with the following:
platform: state
to: 'off'
for: '00:15:00'
service: automation.turn_on
That will turn the first automation back on if itâs been off for 15 minutes.
Once per day would look like this:
platform: time
at: '00:00:00'
Thanks for the info, i already know that there are multible ways to do this.
All are, for the fact that this is a basic and needed task for automations way to complicated.
For your way:
What do you mean by this? You could add a condition to only call the automation.turn_off service if the cooldown automation is on. But I suppose that adds to the first issue you listed.
Could you please tell me some usecases for this?
Hello from 4 years in the future. My specific use case is to prevent the occasional issue where an automation will run about 15 seconds later after running for the first time. I have an automation set to run when myself or my wife leave the house, and then an automation to run when we get home. If we both leave at the same time, every once in a while there is some odd race condition where the âleaving homeâ automation will run, then the âarriving homeâ automation will run 15 seconds later or so, even though we both are now gone. I imagine this is because of how I track home occupation, etc. So having a âcooldownâ on this automation prevents that from happening. Just dropping this here for posterity since I came across it in my search for a solution.
Given how easy is to add a template condition with the following code:
{{ (as_timestamp(now()) - as_timestamp(this.attributes.last_triggered))|int(0) > 600 }}
(600 seconds = 10 minutes) I still do not understand why they donât add a âcooldownâ feature to the dropdown menu in the automation conditions that does the same thing.
If youâre interested, you can simplify the template condition to this:
{{ now() - this.attributes.last_triggered > timedelta(minutes=10) }}
However, both of our examples will fail for a new automation (an automation that has never been triggered yet) because the value of its last_triggered property is none.
This version mitigates that initial situation:
{{ now() - this.attributes.last_triggered | default(as_datetime(0), true) > timedelta(minutes=10) }}
The majority of Home Assistantâs new features are added by volunteers. So the answer to your question is that, for the past 4 years, nobody has been sufficiently interested in this feature to put in all the work needed to create it.
FWIW, the majority of Feature Requests remain unfulfilled; there are more users submitting ideas than volunteers available/interested to implement them.
Iâm interested, thank you very much!
Of course, thatâs normal. But maybe these âbasicâ features also help newcomers to face with Home Assistant (who probably doesnât search through the community posts at all
The Automation Editor is designed for novices. In other words, it doesnât expose all of Home Assistantâs scripting functionality and limits itself to basic, commonly-used features (to avoid overwhelming novices).
Advanced features and concepts are implemented in YAML and/or Jinja. Thatâs yet another reason why this FR is unimplemented for 4+ years.
For anyone else landing here after searching for âHomeAssistant automation cooldownâ âŚ
I found that last_triggered doesnât work, because when it evaluates that condition, the attribute has already been updated to now(). So it never evaluates to true and the automation wonât run.
Instead, I ended up adding a timer as described in another post â add a Delay as the last action, and make sure the mode of the automation is set to âsingleâ
Thanks. I was just recently trying to do something similar and I couldnât figure out why this solution didnât work. But⌠Are you sure? It really doesnât make sense to me that the attribute would be updated before conditions are evaluated. It means it is updated even if the automation wasnât run, because the conditions were not met. As far as I can see, this is not true.
Yeah just double checked, I have an automation showing the last trace at later time than what is the last triggered attribute. But in that later time the automation didnât run, because condition was not met.
Ah, youâre right! It does work, using last_triggered.
Turns out I had another bug preventing my actions from running. But when I looked at the traces, I was looking at the most recent which said âStopped because a condition failedâ ⌠and that was really just the condition doing itâs job, because it had also just fired (and failed differently) a few seconds before.
So thanks for making me double check, @Fanful ![]()
So perhaps some of you can coach me a little? I am one of those novice users whoâs getting pretty good at the GUI, but still a little lost figuring out how to do things with YAML without some explicit instructions. I can do the cool off timer, thatâs easy, and I can see where I can list a condition where only if this same automation was last triggered, but no idea how to specify the condition within. I donât necessarily want to cool off the automation every time either. So asking for some help on a condition like, âIf this automation has been triggered more than 3 times in 5 minutesâ or something similar?
hi
i hav a unifi camera having motion sesnor, I would like to get the notification through hodpod, everthing works fine but there is no cold down time. so it will keep notify while people passing through that area.
this is my yaml.config would like to know how to set a cold down time like a 10 sec cold down so it wond keep notify when people still in that area.
many thanks
- alias: ć¨ć˘Żĺä˝ćććĺ ą
- platform: state
entity_id:
- binary_sensor.dian_ti_motion
to: "on"
- service: media_player.volume_set
entity_id: media_player.3lou
volume_level: 0.6
- service: tts.google_translate_say
message: "ĺć¨äşé"
language: "zh-tw"
# ĺˇĺťĺťśé˛
- delay: "00:01:00"
mode: restart
Change mode: restart to mode: single.
Add this line below it:
max_exceeded: silent
Remember to change the delay line above it if you want 10s. Itâs currently set to 1 minute
