Add core climate support to the SleepIQ integration
The SleepIQ library supports setting the core climate heating/cooling and timer. Can this functionality be added to the integration as well?
I have this same question. I have a Climate 360 and would like to be able to automate setting the bed temperature. The attached is a screenshot from the app. FYI, Foot Warming is already included in the integration, but not the Core portion.
I’d like to add a +1 to this, after seeing that the SleepIQ library has this functionality. I’d also really love to have the firmness be a little more… “forceful” with its values. The bed has some fairly outdated tech capabilities (for a brand new bed) where you can only change 1 value at a time, and you have to physically wait for that value to finish before you can change any other value. If I change anything and then my wife changes her side before mine is done, it stops mine from updating any more.
Is there a way to implement this outside of my own automation, where a number for head/feet/firmness can be brute-forced to go to that, even if interrupted by a different variable changing? Or is that something other people are just implementing via their automations?
I just upgraded from a basic sleepnumber bed from 2016 to a ClimateCool, also curious about automating the cooling level + time rather than using the scheduling in SleepIQ app.
I tried intercepting some calls from iPhone app but think someone smarter than me might need to figure it out.
+1 … having the core warming and cooling functionality in this integration would be great to see. Thanks for the consideration!
