Add Date as name of card
Hi, I’m trying to add a simple date to the name of a card.
I’ve added in config.yaml:
- platform: time_date
    display_options:
      - 'time'
      - 'date'
      - 'date_time'
      - 'date_time_utc'
      - 'date_time_iso'
      - 'time_date'
      - 'time_utc'
      - 'beat'
and I’ve added this card to Lovelace:
type: entity
entity: sensor.time
icon: false;
style: |
  :host {
    text-align: center;
  :header {
  visibility: none;
  padding: 1px;
  margin: 0px;
  .value {
  font-size: 48px !important;
  font-weight: larger;
  padding: 12px;
  height: 90px !important;
  vertical-align: text-top;
  text-shadow:
    1px 0px 3px #444, 0px 1px 3px #eee;
  text-shadow: 0 1px 3px #000,
               1px 1px 3px #111;
theme: synthwave
name: [ current date to be shown here]  reading from {{sensor.date}}
So i just need to have the Date as the name/title of the card…
I’ve tried to put the sensor.date into a variable and to be shown as name: but did not succeded
Also I’ve tried to show directly the sensor.date as the name but got [object Object]
Any help is really appreciated.
B.
Please try something like this, not sure if this will work.
'{{ now().timestamp() | timestamp_custom(''%I:%M%p %a %h %d %Y '') }}'
Hi, welcome to the community.
You cannot do template the way you want in lovelace, try using the config-template-card.
That card opens up possibilities to lovelace customization.
Have fun.
Hi, sorry for the late reply,
I have tried @sheminasalam option but unfortunately no result. the code can’t be interpreted correctly by Lovelace and is displayed as string.
@JTPublic, thanks for pointing me in that dirrection, it looks like the config-template-card is what I need and I try to wrap my mind around the code.
At a first glance looks like it is a bit difficult to add what I want but I am positive that it can be done.
So I’ll dig further :slight_smile:
Thank you again for your advices and support !
I’ll post back the result (if it works)
B.
This may help you started :slight_smile:
       - type: 'custom:config-template-card'
        entities:
          - sensor.time
          - sensor.date
        card:
          type: entity
          theme: synthwave
          entity: sensor.time
          name: "${ states['sensor.date'].state }"
          icon: false;
          style: |
            :host {
              text-align: center;
            :header {
            visibility: none;
            padding: 1px;
            margin: 0px;
            .value {
            padding: 12px;
            text-shadow:
                         1px 1px 3px #111;
Yes that’s exactly what i wanted to acheive
up until now i managed to make this card:
variables:
  DATA: 'states[''sensor.date''].state'
entities:
  - sensor.time
card:
  type: entities
  entities:
    - entity: sensor.time
      icon: false;
      style: |
        #div.info{
        text-align: left;
        padding: 5px;
         .hui-generic-entity-row, .text-content {
        padding: 10px;
        height: 30px !important;
        text-align: center;
        text-shadow:
        1px 0px 3px #444, 0px 1px 3px #111;
with this result:
Thank you, I will use your example.
B.
