I recognise the need to keep the GUI simple, but there is also a need to encourage more to be done with the GUI for the widest user base.
A good new feature would be to add delay on/off into the GUI for a template helper. Holding the state is useful for creating picture element conditions, which can be edited in the GUI,
I beieve this would be a good next step, simplifying the creation of these templates by using the GUI but without adding complexity.
Can you elaborate on use cases for this? When would you use it, as opposed to for instance a threshold sensor? And I do not mean where (the picture element) but what kind of sensor and why?
As a good example, it would be a very simple way to implement a motion sensor that holds detected, giving consistency between icons on a picture element and any automation. This can be done in YAML, but the GUI provides a good way to a novice to achieve this as it’s a really common thing to do. Not all motion sensors are used to turn on a light, they could trigger anything.
Likewise, some sensors have the threshold set within them and just supply on/off to home assistant and so are therefore a binary sensor. I have a light sensor that triggers on/off, based on a preset threshold within but does not provide the light level to home assistant.
A switch is another example, you may wish to hold for a moment after turned off the switch (for example to leave the room).
As this feature request is for a binary_sensor, a threshold sensor makes no sense since a binary sensor is just on/off.
If multiple automations use these sensors, changing just one place to alter a delay is also a simplification.
Thank you. Yes, I found exactly the same as i forgot how useful the delay_on/off is.
It is a very elegant solution, which i feel would benefit users who don’t want to dabble in YAML, it is powerful yet simple to understand the concept.
I believe the UI would significantly benefit by this addition, any complexity of new features to the UI is far outweighed by the overall simplification for less experienced users yet powerful.
This feature is aready availble in YAML for template binary sensors, it’s called delay_on, delay_off. It’s just not shown in the UI yet.
Therefore, “freezing a state” of a binary sensor is a feature already and yes you can, I and others use these currently and it’s really powerful. There is no need for a variable, a variable adds complexlity and that goes against the reason for this feature request.
For clarity, this feature request is simply to add these two options to the UI. Under the covers, home assistant already supports this.
I would love to see the option for delay on//off in the ui now that the templating helper has grown in its options. I want to move away from directly editing config file where possible.
Template sensors crested through the UI can now be linked to devices (which for me there is always a device my template sensors are related to), but due to technical limitations this cannot be done when making a template sensor through YAML.
I’d really like all of my template sensors to be able to be attached to devices, but of course you cannot as soon as you need to use more than just the template condition itself.
So i think expanding the UI helper for them to include as many of the currently YAML only features as is reasonable would be best.
+1 from me. My use case that made me look into this is a simple one. I need to debounce a binary sensor that relies on two conditions with one being true and one being false, and a change in the state of one triggers a toggle of the other. I use this for detecting edge cases where certain toggles can be changed manually but are usually automated (e.g. a “call for fan” toggle and a fan switch).
+1 for me. I just want to move away from manual sensor yamls to gui helpers.
With that said, bloating anything in the gui with what is doable in yaml is obviously not reasonable, but available functionality shouldnt be limited to people who can code or work “under the hood”. So I think any and all available options and functionality should be accessible in the gui, but why not in a toggled/expandable “advanced options” mode or similar, which could be a generic element throughout the whole gui?
That way the gui doesnt get bloated, all functionality is available from the gui, and all non-coders would get at least a chance to look into the power that HA has to offer…
I was doing some research as I was trying to implement this delay via the helper. However, this thread appears to be confirming that you cannot add delay via the helper.
I suppose I need to focus on learning how to do use templates via YAML.
