Right now, the only simple way to manually trigger a script is to put it into a group. It then appears in the UI with the script name followed by either an “ACTIVATE” button (if the script runs quickly) or a switch (if the script contains any delays).
That’s a great default behavior, but it’d be lovely if we had some control over it. For example, I just wanted to insert a couple seconds’ delay between two steps in a script, but to me it’s still an “immediate” script — it feels like the wrong UI to flip a switch and then watch it quickly flip itself back.
Could we add some option or parameter for overriding the default, allowing us to ACTIVATE a script even if it has a delay, or maybe even display a switch for scripts that currently show ACTIVATE? (I’m not sure why you’d do the latter… but it really ought to be up to the user, right?)
Thank you, but input_boolean appears to suffer the exact same limitation: it always appears as an on/off switch. I want a push button (that simply triggers a script when pressed).
